Hey guys just got my trust m-spec cooler for my r33 series II.. Has anyone here cut a 3inch hole near the washer bottle? or so? apparently if cops see if they wont like it.. they will canari you or something... Is this true or not? Because im confused.. either doing my trust greddy cooler factory route to return pipe or cutting the hole where the pipe goes accros the radiator.. thanks..
If anyone has pics please post up thanks
Geraus.
shit sell it if your going the re-route option, not gonna work nicely. Get the BLITZ LM.
otherwise cut the hole, i put my s13 through dandy with a hole through the battery tray. it is not structural and after a blue with the officer they rang one of thier approved inpsectors and he said the same thing... so long story short i got through. Your even luckier with a skyline as the hole is in the same place as GTR's.
Either way it just gives them another reason to pick on you.
I went the return flow setup, which runs the factory way. No cutting holes or moving shit.
In the end, who can be fkd with cop trouble?
exactly, if you dont want to put up a fight then go the blitz, if not go the greddy. If you do it neat enough most dont pick up on it but the decision is yours.... just dont modify the greddy one... its a waste of time.
Thank you so much for ur help, Im just still thinking either to cut the the hole or modify it..or try to sell it... Would it be hard to sell again? because i just brought it last week from CJ motorsports...
Edited by geraus
I think your better off selling it mate rather then modifying it and fking it up.
Just sell it, cover your loses and buy a different kit or if you want to use it, use it as is.
If you modify it and want to sell it later down the track, I think people would be less likely to buy it so you will lose more money in the end.
Edited by abu
Dam, So theres no point modifying the pipes to return? or it wont even work properly...
Na don't bother man, waste of time + more money!
Keep it as is, or sell it off.
Plus the cooler isn't setup for return flow, the end tanks are slightly different for return flow coolers.
Edited by abu
It is highly illegal depending on circumstance, Trent you would have gotten through as its not illegal (see below).
There are countless threads in the vic section about this issue.
Long and short of is if you have a car with AIR BAGS = Illegal.
No Air Bag = legal
HR31 GTSR - no Air Bag = no problem = i love my old shit bucket
S13 - no Air Bag = no problem.
R33 - no Air Bag = no problem.
R33 (i think S1.5 and S2) - WITH Air Bag = illegal
There is no VASS engineer in this state that will ever sign off on a Air Bag equipped model car, being safe with holes cut into the car.
And no, before you ask... you cant remove the airbag from a car that came with one to "make" it legal
Cheers.
Here, have a look at this link below
http://www.skylinesaustralia.com/forums/Su...te-t190267.html
This picture below is a return flow setup, you can see how the end tank on the drivers side curves downwards and back towards the passenger side of the car.
Thanks so much guys, thanks so much for the infro and help. I guesse im goan go the blitz LM hopefully someone nice will buy my brand new kit trust/greddy kit. which is in the sales section.
Thank you. once again guys.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
