Hiya,
Catch can i fabbed today.
3 inch tube split in 2 halves, then adding 80mm flat section to expand the volume and allow for weld on fittings for the hoses.
Has a hole in the base to allow for drain back into the sump.
Has internal baffle to for oil mist to collect on inner baffle, didnt use the metal scourer stuff in the stocking as the oil drains back into the sump so if anything would happen to the stocking or scourer it would end up in the sump..
here are a few pics of it so far, its blasted ready for the powdercoating
yet to do :
Weld on fittings for breather lines and drain back
Powder coat it
https://www.sau.com.au/forums/topic/199467-todays-catch-can/
nice work mate, cant wait to see it finished...
I just want you to make me a copy of all of this stuff your fabbing!!
haha soon soon, i havent touched a welder in a few months, since the one i was using went back to its owner :)
this particular catch can has given me some ideas on the internal workings of the washer bottle catch can in one. so hopefully i can get one of those working soon.
hehe funny you mention the washer bottle/catch can combo...been wanting 1 of those for a long time now...
here's some pics of 1 if you need any ideas
I'd definitely be interested in one of those if you got around to making 1 :devil:
Edited by **JaR**
AHAH!!!
the hardest part of it was seperating the 2 parts, now on theirs they make 2 cans and then weld them together ..
that should make it easier, just uses more material.
Cheers for that JAR
Dont forget that in a road car the catch can cannot vent into atmosphere, hence no filter at the top.
yep thats right Charlie.
1 in - 1 out and the drain.
The Rips style would be a little messy to plumb back, but not impossible
Edit : that R33 pictured is setup wrong all together :D - kinda defeating the purpose
last pic, rocker cover still connected to the intake pipe.
lets it draw air from the filter on the catch can, plus would let oil mist go that way as that would be the easiest path for it - rather than going through the catch can first
yeh i noticed that too, if that pipe to the intake is blocked it would be okay yeh?
yep, that little one that loops over
still lets some air into the plenum if you leave the pcv open though- only on idle though
Edit : that R33 pictured is setup wrong all together :blink: - kinda defeating the purpose
Actually that pipe is a bit of a trick lol, i had nothing to block up that breather with so left the standard pipe that normally goes to the intake pipe on but blocked up the end of it (the hole in the intake pipe was blocked up aswell ofcourse), i have since got a rubber cap to block off that breather.
Thats my car by the way :), basically my setup is just the two breather pipes coming off the cam covers going into the RIPS catchcan, everything else was blocked off, my setup is illegal in aussie from what ive read but you could always just weld another fitting onto the catchcan and run a hose with a pcv/one way valve back to the intake manifold to make it legal over there, would be easy enough.
You can see in these pics how that breather was blocked off
Edited by nizmo_freek
ahh yes
tricky tricky :blink:
few little extra additions in there now too - nice
hehe, cheers :), should have another new addition in there soon, ive got a hks 3037 pro s turbo kit on its way from japan :D
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
