Nice work Chris! Just thinking if it's worth fitting another two baffled plates, on either side of the existing one, spaced about 5mm apart, with the holes offset, to ensure the mist just doesn't pass through.
As i have no ABS in my 33gtst, my mechanic has fabricated a baffled catch can in the ABS location. It too is drained directly into the sump and vented into the intake. Will post pics once car is done, probably in a couple of months.
That is probably a VERY good idea.
although it is a little late for that, it will be done with any more i make, this is still a better catch can than most off the shelf ones like the trust units which are just an open can.
i'll be getting the fittings for this tomorrow, so i'll get it welded up and powdercoated by the weekend.
Second pass over alloy bead, I'm assuming that u mean with out filler.
I have done this when I messed up welding some 3mm to 10ish mm alloy in a vert fillet, It didn't look nice enough went over it and it still looks shocking.
Flattens out all those lovely ripples.
thats exactly what i meant, and that news wasnt what i was hoping for ;)
Looks good, what thickness filler did u use?
I should get off my butt and have a go at making one of those RIPS style catch can/washer bottle combos
got plenty of 3mm plate but aint got plenty of spare time.
to be honest i dont know the thicknesses of the filler
only got 2 sizes available to me, so i used thin - maybe 1.2mm for the walls and thick -2ish mm - for the fittings.
Turns out that sandblasting the part does some funky stuff when you try to weld over it, wasnt working well with the thinner filler today.
What are u sandblasting with? It is possible to embed contaminates into the aluminium.
I've managed to contaminate the stuff with a file (somebody borrowed it and was filing some old rusty steel) that I neglected to check/clean.
i only blast with Garnet (sand) so it wasnt contaminated (no black spots like you would get with the steel from another file)
it affected the way the base alloy would melt, just seemed to take longer which meant that the weld ons where at the point of melting where the base wasnt.
hard to explain since i havent done any formal training in welding.
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
