Hey all,
Had my RB25 exhaust manifold repaired recently (broken stud) and a boost leak resolved.
But with the boost cranked to about 8-9psi i find there's no 'kick' and less response when i floor it. It used to launch hard before, but since the boost leak began and even after repair, the power has not returned.
My mechanic said i need to fix my timing. I.E. get an ECU retune/piggyback/PFC?
If it helps, my boost gauge under-reads at idle. It used to sit on -0.5 BAR all the time, but since then it's always sagged less than that. Even AFTER the repairs.
Any recommendations here?
Cheers :)
https://www.sau.com.au/forums/topic/199494-lazy-r33/
  R338OY said:
"Had my RB25 exhaust manifold repaired recently (broken stud) and a boost leak resolved."
"My mechanic said i need to fix my timing. I.E. get an ECU retune/piggyback/PFC?"
Howdy R338OY,
Even someone with the most basic mechanical logic would be scratching their head at what your mechanic has suggested!
You told us that it went in for a basic stud replacement and to resolve a boost leak, however prior to this the car performed well. Now the stud is repaired but the car doesn't "go". All the mechanic can suggest is that if you want it to go again, you have to alter your timing and buy a replacement ECU!?????
Here are two suggestions for a start:
1/ NEVER go back to this mechanic.
2/ Let us know what area you live in and someone from the forums could suggest a REAL mechanic in the vicinity that can quickly diagnose your car and get it sorted once and for all.
I can't see, based on the repairs you had done, how the problems you were experiencing have anything to do with a fault in your ECU or your timing, otherwise your car would never have driven properly in the first place. Besides, the repairs you had done would have been accomplished without the need to touch either the ECU or timing.
The first thing that springs to mind from my limited knowledge together with the explanation you've given, is that there could potentially be a vacuum problem. If this fool has accidentally disconnected/crimped/blocked a vacuum line as a result of his fooling around, it could be messing with your wastegate actuation or the ECU could be responding to a lack of vacuum elsewhere and its interpretation of this could inadvertantly be causing the poor performance.
Have someone who knows what they're doing check out all of your vacuum lines first. It could potentially be the quickest, easiest and cheapest fix. If this isn't the problem, then work through the basics as there would be a simple explanation for this and it should be directly related to the repairs that were performed. By fixing the stud, the mechanic may have had to remove the entire manifold, which of course has the turbo and exhaust attached. If he has reassembed this incorrectly or forgotten to reattach something, the car could perform poorly as you would expect.
Don't look at anything else until you've checked these BASICS first (vacuum lines, sensor connections, mechanical connections..etc).
Hope that this has been of some help.
Cheers, Mike
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3555733
Thanks for the responses fellas.
Yes i'm no expert, but i always thought the wastegate/actuator had an issue with building boost pressure. That's just the feel i get from driving it. It makes full boost but is lazy from low RPM's, i.e. it used to 'launch' when i floored it, now it's not that responsive. I can feel the lack of pressure from mid-->high RPM's too so it's obviously a small percentage of power being lost, but affects overall performance.
I'm sure it's not a complex problem. I'm going to have someone diagnose the issue, and someone who knows what they're talking about :devil: .
Cheers
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3556022
hey guys im new to driving skylines as i have bought my first just recently (r33 gtst s1). the one thing i need to do is replace the exhaust manifold, but i need some advice as i dont want mine to lose power after some mechanic plays with it.
1st question is should i go all out and get an aftermarket manifold such as a hks one or just replace it with stock?
2nd question is could any1 give me an idea of how to replace it myslef?
thanks in advance!
ps... good luck with fixing the problem R3380Y
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3556197
thanks in advance!
IMO you need a mechanic to replace it if you're not experienced. The mechanic took pics of mine and there's all these wierd studs to move, and you need to know how to remove the turbo, plus intercooler piping, without damaging anything. Plus if you do up the manifold studs too tight they can break off and you're screwed again.
From what i know the stock manifold is top stuff for being stock, and you won't need an expensive HKS one unless you want to A) Run massive boost B) Install something lighter. It's effective and solid.
  Adriano said:
r33boy, maybe check the tension in the wastegate actuator.
How do i check it? Thanks for the advice.
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3556774
I would disconnect the wastegate arm from the flap pivot on the exhaust housing, you need to check 2 things, the preload(how far you have to pull the "arm " out of the wastgate can to hook it on) it should be about 2mm. The other thing to check is the tension of the spring in the wastegate can, pull the arm away from the can, you should be able to move it 12-15mm but it should be quite hard to do so. Some other potontial problems with the wastegate can be a badly cracked exhaust housing/wastegate flap or a wastgate flap not seating properly, all these problems will cause slow boost build.
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3556800
  victorian said:
lol you need a mechanic to take a turbo off and intercooler piping what a joke
The dude i replied to just bought his Skyline. Not everyone is as expertly experienced as you mate so, like i did, give out sensible advice that will help other drivers maintain their cars.
Thanks for the explanation, i'm going to investigate it asap and forever bury this problem! :D
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3556835
thanks in advance!
use a stock manifold making sure it aint cracked and change it yourself, its not that hard.
locate manifold and remove. replace manifold, if your worried about breaking studs use a torque wrench ($50). just be gentle don't use to much force on anything.
Make sure you are careful undoing the manifold as this is when you are more likely to break studs. use alot of wd40 when engine is cold and do a couple of time over 30mins to let it soak in before undoing the manifold...
you will learn alot and feel good when you finish and if you stuff up or studs break you will learn more... all good...
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3556845
Don't break the studs. If you're that unlucky you'll have to get the stud drilled out (as was done to mine) and there aren't many thread-drillers in Sydney. If you need a contact for someone to drill a broken stud i have a number you can call.
A fresh manifold gave me a massive improvement to building boost.
https://www.sau.com.au/forums/topic/199494-lazy-r33/#findComment-3557424
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
    • Thank you so much for the comments.  This is very interesting and gives me some great ideas to think about. Keen to keep it simple and relatively classic looking. That said, i am not too worried about staying 100% period correct.  A little extra performance and relatively good (or improved) economy is just what i am looking for. Ill be keeping any parts i swap out so if i get nostalgic i can always swap it all back in.  Right now just trying to get some good ideas from people in the know (I still have a lot to learn in this space). Thank you again!
    • Wrt the engine, you're very much limited by 'production quality' as to how much extra power you can extract from them (I'm talking i6 red-motor) -- a lot here depends on how 'authentic' or 'period correct' you want the modifications to be... ...I'm too old... <grin>...the first true performance engine Holden made, was in the HD/HR models ~ this was the 'X2' performance pack...it came with twin downdraft strombergs on an otherwise unimproved intake manifold, with a two piece exhaust manifold (reckoned to be as good as extractors)... ....these engines were built upon the '179HP' cylinder block, which included extra webbing in the casting to make it stronger and less susceptible to block distortion... The next performance i6 came out with the HK Monaro (also found it's way into the LJ GTR Torana ... the car I wish I hadn't sold)...it had pretty much the same manifold setup, but was built against the '186S' block...this block retained all the extra webbing of the 179HP block, but added a forged steel crankshaft (instead of the stock cast crankshaft), because it was possible to snap the crank... ...apart from the inherent weaknesses in the stock (cast crank) blocks, the next limiting factor is the cylinder head porting & combustion chamber design, and the actual valve sizes. Back in the day, you could buy a 'yella terra' cylinder head (from stage 1 to stage 5 gradients), and this was the way to get serious power out of them -- with the extra breathing of these heads, you could fit a triple SU or DCOE Weber setup... ...obviously, these mods were a waste of time on a stock cylinder head/camshaft grind. My housemate rebuilt the i6 in his VH dunnydore about 6 months back -- this is a 186S block with the 12port 2850 blue motor head and intake/exhaust manifolds, with a dual throat Weber off an XF Falcon mounted on an adapter plate ; it's not a bad makeup...got more torque & fuel economy just light-footing it about on the first throat, but stand on it and it makes more giddy-up than the standard 2850 blue motor that it replaced. Personal note: I'd just fit an RB30 and be done it it 馃槂
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
