I am wanting to get started in a bit of track day action but would like to upgrade the braking system on my r33 gts25t. I have seen that DBA are now making a 2 piece slotted rotor. Basically i wanted to get some feedback on how much of an imporvement a set of 2 piece rotors and say bendix Ultimate pads would give over the standard R33 brakes. Also what type of brake fluid is the best for street/track applications? (brake fade sux).
How far can you go perfomance wise with the standard calipers before a new calipers would be needed? which is a quite expensive option.
https://www.sau.com.au/forums/topic/19959-brake-upgrade/
Im still running std calipers, but use good fluid and braided lines.
When at the track i use an R compound tyre so is nice and grippy and in turn stresses the brakes even further.
Im only sporting mild bolt on engine mods and have found the factroy brakes work a treat. My only downfall was thinking half worn pads would get me thru a day at the track. I was wrong and in turn ruined a set of front rotors.
So for this reason i upgraded to one piece 330x32mm front rotors just to cover future mods.
So, unless the front rotors need replacing, my thoughts are save your money until they need replacing as they will serve you fine in the meantime.
As for pads and fluid, i have found RB74s from Race Brakes, and AP DOT5.1 fluid do the job fine for me.
https://www.sau.com.au/forums/topic/19959-brake-upgrade/#findComment-420597
My thoughts exactly...
My car doesn't pull up anywhere near as good as what another guys does and he is using the standard GTS-T brake kit and im using the DBA's. He just 'knows' how to use his brakes in a better fashion (yup their is alot more to it then just pushing your foot down).
The standard Rotors are damn good for what they are worth. The only thing im not too sure about is how much heat they will generate on 5x 7 Lap sessions (I didn't make it that far coz i was using the standard fluid).
Don't even bother attending a trackday without using brand new DOT5.1 brake fluid. I live basically about 5 streets away from the Eastern Creek track (with a 20km Motorway inbetween those streets) and after 3x 7 Lap sessions I cooked my DOT3 brake fluid and barely made it home alive (lucky i only had 4 sets of traffic lights to contend with, anymore and i woulda been using the handbrake to stop).
So my conclusion of a first time trackday attendee would be:
* DOT5.1 brand new brake fluid
* Bendix Ultimate or better pads (depending on your bank balance)
* Don't try and break any records on the first day
* A nice helmet and a mate to have a day full of fun.
https://www.sau.com.au/forums/topic/19959-brake-upgrade/#findComment-420604
Dont trust Ben, i think he works for a major brake fluid manufacturer.:D
Or is it the simple case that after some serious fade at Eastern Creek he knows better then anyone how it can ruin a good day at the track, or worse cause it all to end in tears.:(
You sure you dont want those tyres Ben, i know a vet, he can hook you up with a certificate from a doctor, well kind of.:)
https://www.sau.com.au/forums/topic/19959-brake-upgrade/#findComment-420617
You sure you dont want those tyres Ben, i know a vet, he can hook you up with a certificate from a doctor, well kind of.:rolleyes:
hehe i paid Bob Jane T-Marts $1.50ea to take away my old tyres today (Bought a brand new set of Michelin Preceda's and damn they are nice).
I woulda kept them except well... a set of tyres is useless to me when they dont have rims, besides the tyres were just not built at all for any trackday use and my laptimes were showing it.
I did a small finance ordit this arvo and im basically broke now for 3mths. So I can't see myself driving around a track until Xmas but by then it will be a whole new ball game. (Oil cooler, track tyres, etc).
https://www.sau.com.au/forums/topic/19959-brake-upgrade/#findComment-420625
Cool, im penniless too at the minute, but a boy needs to still have his fun.
So much so that im going to work this Friday/Sat/Sun even though im on holidays and was going to go to Wakefield on Saturday. If they want to call me in from my holidays and pay me double time... well the money wont go astray.
Oh, and Bleach you coming to Eastern Creek on the 24 July? Get those pads and fluid so you too can lap my speed limited R32:(
https://www.sau.com.au/forums/topic/19959-brake-upgrade/#findComment-420636
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
