I have 3 items for sale:
1. R33 GTR Series 3 gearbox, has stronger synchros than series 1&2, has been pulled apart, checked by professional gearbox rebuilder, in 'as new' condition. This has been converted to accomodate for a push type clutch, but can be changed back to pull type. Please specify when purchasing. It also has fresh redline oil (not cheap) and has done 500kms.
Price $1900 ono
2. R32 GTR gearbox has been pulled apart inspected and had new bearings installed, in excellent condition. Has no oil and has not been installed in car since pulled apart.
Price $1650 ono
Note: Both gearboxes have transfer cases attached and can be inspected/picked up from Racepace Motorsport in Bayswatrer (Melb).
3. Exedy twin plate clutch (push type) to suit R32 GTR or R33 GTR gearbox that has been converted to push type, in very good condition has plenty of life still in it. This clutch supported 350rwkw reliably for the last 2 years and has never slipped. I'd say it has done about 5-6000 kms with no 'hard launches'.
Price $1100 ono
Post here or PM if interested.
Can ship interstate at buyers expense.
Cheers,
Jack
Price for series 3 box without transfer?
My 4th syncho is f**ked...
my gearbox in my previous gtr was the same - 4th gear over 100km/h was torture!
i then tried redline...it NEVER crunched again regardless of speed i was changing at (200km/h +)
trust me it works :( just try it for $100!
(sorry to hijack thread)
Price $1900 ono
Price $1650 ono
Price $1100 ono
Cheers,
Jack
Do you still have R33 Gtr Gearbox for sale?
  • 2 months later...
May be interested in the 33 gearbox if you still have it, mine has just jagged in and depending on how bad it might be cheaper to get yours
GTRsean's gbox alone was $1975 to rebuild with new synchros and bearings, after buying it second hand for $700.
These gearboxes are a bargain guys!!!!!!seriously, no more crunching!!
Cheers Joshua!!! :)
The gearboxes were priced to sell hence why I wasn't asking for ridiculous pricing considering the work that's been done to them..
As you can see, I haven't been bumping the thread every day so I'm not desperate to get rid of them either.
If I don't get the price I'm after they can sit at Racepace for ever.
In saying that the 33 box has been sold pending payment, and the clutch has also been sold.
So the 32 box remains..
Cheers
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
