Can anyone help ???
I got a r33 gtst and the oil pressure never goes under the second line (before the 4) but my friends RB25DE r33 goes all the way down to close to 0 when its idle.
The car makes a weird sound when its at idle (she calls it the gremlens) but its like a howling sound. Could that mean the oil pump is stuffed?
as soon as you raise the revs by at least 300rpm the sound goes away and oil pressure goes back to normal levels. (just before the 4 or abouts)
When driving its fine......
Whats up with the beast ? does it really matter to have close to 0 oil pressure on idle ?? The engine is NON turbo...
When I put 5w-50 fully synthetic oil in my car I had the same problem. I then put some 10w-50 in and the problem went away. My conclusion was that the oil was way to thin for the engine.
This may have something to do with the problem your friend is experiencing.
I thought it was 7.5W-30 factory recommended. I'm using 5W-30 and don't have any oil pressure problems. I actually slightly over-filled it and I was waiting for some of it to burn off but it's not happening.
Guest RedLineGTR
As far as i know on a proper idle from factory specs when the car is at optimal operating temps it meant to sit on number 1, 1.5...
I been using 5-40w oils the pressure is exactly the same as in facotry specs, i tried a more expensive oil 10w-60w abit high but oh well though i tried it, the oil pressure was sitting at like 3-4 nearly double, it was too thick, very high tech engines and the oil aslo dosent get around everywhere it supposed to be. Probably wouldnt go over 10-50w maybe 10-40w would be perfect.
the stock gauges / senders read low, regardless of what oil you use (i have tried many viscosities) when warm. I have an aftermarket Trust oil press gauge and when i'm revving it the stock gauge reads just over 4, but the trust one is at about 6-7. Don't worry too much, @ idle the stock reads about 1, the Trust one at 1.5. :D
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
