Make: Nissan Skyline
Model: 1993 R32 Gts-T
Milage: 86***
Transmission: Manual
Colour: Black
Complied? no
RWC supplied? no
Currently registered? no
Price: $12000 with blueslip or 10500 unreg.
Contact: 0405 063 382 OR pm!
Comments / Modifications: Stock apart from muffler, Apexi pod, JJ front and rear strut bracers, Gfb boost t and MoTec fuel Reg(also belive car has MoTec 400hp or 500hp fuel pump).
car has tien coilovers 17's No idea what brand missing center caps and some decent rubber.
all belts where done by pitwork in jap.the car has work side skirts orginal vertex front bar.
the car has seen one wsid night and ran a 14.2.
Car was dyno'd and serviced at C&V Performance 157kw/15psi ( will try to find dyno sheet have slips from wsid but no scanner )
!! Car even comes with 3 year Warrenty with JapLink Motors !!.
Now whats wrong with the car.!!
the front bar has been reversed into no idea on gettin it fixed and the front of the bonnet has a dent in it but nothin that is that serious. one of the front left bush's is stuffed and is makin a tyre hittin guard sound ( had a mate and pedders look at it both quoted nothin over 300 to fix it all up!) cppl of dings here and there. Car was Broken Into and hack'd at the Ignition(replaced with 32gtr ignition) and the passenger side window was smashed also replaced.Still need to replace the center console and under the steering wheel plastic's( http://www.skylinesaustralia.com/forums/We...p;hl=inner+west thread on break in and pic's of damage.)
- start up and a bit of a rev.
http://s240.photobucket.com/albums/ff194/Charlie031/Dean/ album with pics of car
Edited by MRDeanos.
https://www.sau.com.au/forums/topic/199987-1993-r32-gtst-for-sale/
  • 1 month later...
  • 1 month later...
Just a few questions;
Has this car ever been registered in Australia and is it complied, as you mention that you purchased it from Japlink with warranty, but have advised that it is not complied in the first post.
If it has been complied and is now unregistered, how long has it been unregistered for?
If it needs complying, do you know what things need to be done to the car to get it to pass?
i was first owner since it was imported and no idea on what year it came over..
as for the blue slip im not statin any prices come look at the car and have a chat.. kinda sick of people tryin to batter the price when they havent even looked at the car..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
