Hi guys
Just wondering if anyone knows how to wire up the xf throttle body with a vl manual TPS
My car being a auto originally i have two connectors. Just wanting to know which one do i use to the connect the TPS to it.
Any diagrams or explanations or steps would be much appreciated.
THanks
https://www.sau.com.au/forums/topic/200019-xf-tb-wiring-insturctions/
on skylines manuals and auto's both have 2 plugs for the tps. one is apart of the plastic tps moulding and the other is on the end of a short length of cable coming out of the tps unit.
the one on the length of cable is the variable tps output. usually 3 wires, 5v input, ground and variable voltage output. (from memory the middle one on the plug is the output)
the one that is apart of the plastic tps moulding is the throttle on/off switch. usually 2 wires, just a switched, on/off voltage.
Edited by QWK32
I have converted my skyline to manual and have obtained a TPS from a vl manual commodore which has only one connector( does not have the additional wire and connector as on the automatic vl)
Just need to know how to splice in the existing skyline loom to the manual vl tps connector.
i was looking at those billet ones but dont trust them. plus being 250 bucks or whatever they are, and could have the possiblity of getting a poorly made one could stuff everything up .
Xf throttle body being 20 bucks, and knowing that they work. I dont think you can go wrong. Yes they were made in 1972 or whenever and from a shit car ( who cares).
Just wiring issues at the moment but if i find the right information, its not going to be hard to have it sorted.
oh ok, didnt notice that in your first post you said it was a vl manual tps. what ecu are you running? you wont be able to use the manual vl tps with a stock ecu, auto or manual.
the manual vl tps only has the on/off switch, when the throttle is closed the switch is closed. just do a continuity test on the pins until you find the ones that switch.
i was just going by what other people have said that works with the xf throttle body.
I didnt think the standard one would work.
I think i have lost the standard one, i have tried finding it but dont know where i put it. i'll have to keep hunting around, and see it would work.
  • 3 months later...
people that are running the XF throttle body,
do you guys have the air bleeder thing on it which you can adjust or not?
I have one that doesnt have it on it? could this affect idle ? (hoping that ya know what im talkiing about.)
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
