Hi Guys,
I have had my R34 GT25 for about a year now with nil issues.
So far I have had 2 incidents where whilst the car is going, an orange light comes up on my dash, the car then begins to shudder and the exhaust note changes. The car still changes gears (tiptronic), but if I am to try and accelerate it is greatly restricted.
The first time this happened, the car had been idiling for about 2 minutes and the most recent event was driving home last night travelling at about 8okms. Also when it happened the first time, I took the car home, left it until the afternoon and started it. The car drove for the next several days with nil issues. A friend of mine said it may possibly be an issue with the Catalytic Converter..
I have searched throughout this section but have been unable to find anything which relates.
Any help or insight would be much appreciated.
Brenton
https://www.sau.com.au/forums/topic/200254-engine-issues-with-r34-gt25/
Hi Guys,
Brenton
brenton its the guy near your parents here, remember with the orange r33? give us a call and il come have a look mate. been a while, last time i saw you we spoke on the side of the road at unanderra LOL my number is 0422 085 966
Thanks heaps Chook, and especially you Danny Boy, i will get the Iridium's today so we can replace them..
Just for anyone who may have the same problem in the future, it was my coils as they were burnt out, apparently due to heat..
This is true... Hey I started the car today and it sort of muffled a bit, the orange light came on again and I just kept driving it, it started with like light shuddering which passed after a street or 2 of spirited driving. It starting to pee me off. It makes me wonder what the hell is wrong with it, maybe its the coils still...aaaarrggggg...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
