sup guys, happy new years to all yay first post of 2008 piddy it has to be such a sad one:
last night some dick debadged my car and sole my god damn number plates this is the f**ken 3rd time in 4 months someone has f**ked with my car when parked at my house.
i know owning an import can draw much attention and yes some of it unwanted but f**k where has the respect gone these days, i would never consider damaging someone elses property the worlds turned to shit when ur car ain't safe in your own yard.
has anyone rescently had this happen to them particularly around the stafford/chermside area.
cheers guys
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/
Sorry to hear that cccya. Sad to know that there are some people out there with such disrespect for other people's property. Makes me wanna badge my gtr just so i get there before they do so they don't have to scratch the fudge out of the car while doing so. You should prolly go and pick urself up a set of number plate screws. Only goes on, can't remove via screw driver. It's idiot proof, so hopefully that's enuf to throw them off next time. haha.
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3568116
Replace your badges and give her a nice clean on say a friday night and do a bit of a stakeout on it.
YOU WILL NEED:
1 x 6 Pack of Beer (cold preferably)
1 x Packet of cigarettes (optional)
1 x Base ball bat
Done that one before in the slums of Sydney. Caught the f**kers too, red handed. Now Big Bubba is taking care of them... :banana:
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570234
YOU WILL NEED:
1 x Base ball bat
ye mate had already thought bout that the beers add a nice touch to it tho would make the night a lot easier hope i have the same luck guys gonna get f**ked up if i catch him
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570299
2 of my mates in the last 2 weeks have had there cars trashed, both with r33's
one had the rear window smashed and a brick thrown into the rear drivers guard/c pillar smashing the 1/4 window
the other had the window smashed, wheels stolen and interior trashed
i hate leaving my car anywhere now...
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570308
YOU WILL NEED:
1 x Base ball bat
I had my leterbox(1 of them thin metal milk container looking 1s) beat in every night/2nd night for like 2 weeks every day me and my dad were out there trying to straiten it out till we got the shits and did the same thing we set up camp in the front yard(in the bushs) had spot lights all wiered up rdy to blast our entire front yard....
the night we did that no 1 turned up...
night after our letterbox was bashed again
they were obviously hitting it with a baseball bat so... we filled our letterbox with cement :D hit it with a hard baseball bat and u will hurt ur hands.. the next night we here this donk noise.. they never came back since
although this story has nothen to do with cars haven a stake out is a good idea plus its alot of fun thinken ur a ninja hiding in the bushs :D
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570341
agreed then... SAU stakeout... im sick of ppl scrathing my doors in carparks... never had this problem when i was driving my little proton (which is 4 sale btw)... im pretty lucky cuz i have a looooong driveway and a garage... but stakeout sounds like fun :blink:
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3571214
cheers guys
Not quite the same thing but, the first day of the QLD school holidays on my way home from work at 11pm 3 little f**kers thought it would be funny to hide near the cash converters on Stafford Road and throw eggs at passing cars. The result was an egg shaped splatter mark from the egg's shell taking paint off my driver’s side door.
At first I thought it was a rock, chased the little c**ts through the park in a blinded rage with a metal star picket recruited from a near by garden couldn’t catch them (Stupid heavy work boots). :P
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3578349
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
