sup guys, happy new years to all yay first post of 2008 piddy it has to be such a sad one:
last night some dick debadged my car and sole my god damn number plates this is the f**ken 3rd time in 4 months someone has f**ked with my car when parked at my house.
i know owning an import can draw much attention and yes some of it unwanted but f**k where has the respect gone these days, i would never consider damaging someone elses property the worlds turned to shit when ur car ain't safe in your own yard.
has anyone rescently had this happen to them particularly around the stafford/chermside area.
cheers guys
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/
Sorry to hear that cccya. Sad to know that there are some people out there with such disrespect for other people's property. Makes me wanna badge my gtr just so i get there before they do so they don't have to scratch the fudge out of the car while doing so. You should prolly go and pick urself up a set of number plate screws. Only goes on, can't remove via screw driver. It's idiot proof, so hopefully that's enuf to throw them off next time. haha.
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3568116
Replace your badges and give her a nice clean on say a friday night and do a bit of a stakeout on it.
YOU WILL NEED:
1 x 6 Pack of Beer (cold preferably)
1 x Packet of cigarettes (optional)
1 x Base ball bat
Done that one before in the slums of Sydney. Caught the f**kers too, red handed. Now Big Bubba is taking care of them... :banana:
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570234
YOU WILL NEED:
1 x Base ball bat
ye mate had already thought bout that the beers add a nice touch to it tho would make the night a lot easier hope i have the same luck guys gonna get f**ked up if i catch him
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570299
2 of my mates in the last 2 weeks have had there cars trashed, both with r33's
one had the rear window smashed and a brick thrown into the rear drivers guard/c pillar smashing the 1/4 window
the other had the window smashed, wheels stolen and interior trashed
i hate leaving my car anywhere now...
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570308
YOU WILL NEED:
1 x Base ball bat
I had my leterbox(1 of them thin metal milk container looking 1s) beat in every night/2nd night for like 2 weeks every day me and my dad were out there trying to straiten it out till we got the shits and did the same thing we set up camp in the front yard(in the bushs) had spot lights all wiered up rdy to blast our entire front yard....
the night we did that no 1 turned up...
night after our letterbox was bashed again
they were obviously hitting it with a baseball bat so... we filled our letterbox with cement :D hit it with a hard baseball bat and u will hurt ur hands.. the next night we here this donk noise.. they never came back since
although this story has nothen to do with cars haven a stake out is a good idea plus its alot of fun thinken ur a ninja hiding in the bushs :D
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3570341
agreed then... SAU stakeout... im sick of ppl scrathing my doors in carparks... never had this problem when i was driving my little proton (which is 4 sale btw)... im pretty lucky cuz i have a looooong driveway and a garage... but stakeout sounds like fun :blink:
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3571214
cheers guys
Not quite the same thing but, the first day of the QLD school holidays on my way home from work at 11pm 3 little f**kers thought it would be funny to hide near the cash converters on Stafford Road and throw eggs at passing cars. The result was an egg shaped splatter mark from the egg's shell taking paint off my driver’s side door.
At first I thought it was a rock, chased the little c**ts through the park in a blinded rage with a metal star picket recruited from a near by garden couldn’t catch them (Stupid heavy work boots). :P
https://www.sau.com.au/forums/topic/200560-fked-up-vandals/#findComment-3578349
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
