Firstly i have : R32GTR with built motor, R34N1's running up to 21psi.
Iam getting a fair bit of oil in my intake and intercooler pipes and i want to fix this asap. The problem is that I have VERY limited space in my R32 engine bay to fit a catch can.
As I see it I have 3 options:
1 - Relocate the battery to the boot and fit a decent size catch can in its place. This means a bit of stuffing around with wiring and the loss of some boot space. Would have to buy battery box. Is it legal ??
2 - Buy a small $300 odyssey battery which would leave room for a catch can in front of it.
3 - buy one of those catch cans thats sits accross cam covers at the back. See pic below. Would these do the job and do it well? It would be the cheapest and easiest option.
How big does it need to be? Most seem to be about 800ml to 1 litre. Is that big enough for an RB26 that does the occasional hill climb and drag event?
What catch can setup does everyone have in their GTR?
Any suggestions would be great.
Thanks
Tim.
https://www.sau.com.au/forums/topic/200676-rb26-oil-catch-can/
yeh its coming slowly just trying to get my mate motivated to come round is the trouble lol...cruise for sure that be great indeed...i have not been in a gtr for over 18months now and i need a fix lol so the sooner the better...
regarding the catch placement i think ill just put mine infront of battery as it fits nice indeed...your welcome to come round and have a look anytime mate...
Cusco sell a 3L catch can that fits behind the battary. I've got one, it's great.
here's a pic stolen from Beer Baron's RB26 for sale thread of what the can looks like
Edited by sav man
sav man .... The battery I have now is too big but if I bought a smaller battery that is exactly what Iam looking for.
How have you got yours set up ? What inlet/outlets does it come with ?
Where from and how much ?? I can only find the smaller ones on the net.
Thanks
Tim.
Thanks
Tim.
My is setup identicle to the pic. It comes with that clear hose, and a bung to block the breather line going into the turbo inlet. You will need to buy a filter (like $5) to put on the catch can outlet though (the bit on the drivers side of the battary).
www.greenline.jp have them for $179 + postage, Cusco 3000ml car spesific kit. Part # is "231 011 A"
Edited by sav man
i think the battery to boot is a good option.
but as you said alot of work to get it there.
i've been in this process for some time, also building an airbox to suit the trust cross over/hard pipe kit. and a catch can like the arc number with radiator overflow and washer bottle in one..
similar to the 33/34 gtr model but to suit 32gtr
Edited by Angus Smart
if you plan on doing cams events like hill climbs etc check the cams regs regarding catch cans. They need to be specific size etc by engine capacity and whether there externally vented or return to the sump.
Of the top of my head i cant remember the specs.
from memory cams regs state it has to be bigger than the capacity of the engine. hence the GTR racing one being 3litre. the one I have is fitted there with the standard sized battery in place. if yours wont fit there then for some reason you have swapped to a bigger than standard battery (bad idea). it's 3l so in a standard size RB26 if things go wrong it can hold pretty much a whole sump full of oil.
Yes I realize now that I have a bigger battery then standard and I will change it to fit a catch can.
I emailed Greenline about the 3L Cusco one and they said they have none in stock but could get one made.
That ARC one for an R32 posted buy Angus Smart looks ok. Thats the style Iam after. Anyone got any info on it or a link i can go to? Cant find it for sale anywhere or any info on it.
Tim.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
