Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
they are making it from 7701 (GTR) rotors, no issues machining it down to 310mm, all other dimensions are the same, so I will start taking orders now with the next Group Buy...
  • Replies 548
Posted Images
Group buy 32 started:
- twogtrs (waiting for payment to clear)
- RobMz (payment cleared)
R34 GTT owners who wanted the front 310mm plain/slotted rotors:
1. raps86
2. decim8 cancelled
3. vidospace
4. Yo-yo
5. Evil34
1. raps86
2. decim8 cancelled
3. vidospace
4. Yo-yo
5. Evil34
put me down for a pair of r33 gtst 296mm x 30mm rotors
cheers
James
we can't hold the prices forever thus the slight increase - but they're still cheap!
yeah sorry, did not mean to attack prices. Jst stating I had two messages with prices.
so yeah have all the info I need. It does not close for awhile though does it?
I need to redrill them to suit a turbo z31 hub anyway
cheers
James
that's ok :ermm:
yeah, also RDA won't do custom drill the hole pattern, so just take it to your local brake shop...
Group buy opens till 25th June, but if you miss it, next one maybe is in mid July...
Hey
Can you give me a price for Slotted Rotors front and rear for a R33 GTST plus EBC Green Pads all round delivered to Sydney Metro.
Cheers
Last week they told me there was a delay with all DP3826 (rear R33 gtst, R34 GTT, R32 gtst etc) and should be re-stocked yesterday.
Should be arriving anytime soon, I am ordering for myself in this group buy full set of groovies and they have just arrived today!
Got it... RDA has confirmed they've done the first 4 pairs of R34 resized rotors.
First come first serve:
Group buy 32:
1. Yo-yo (payment cleared, front and rear)
2. raps86 (TBA)
3. decim8 (TBA)
4. vidospace (TBA)
5. Evil34 (TBA)
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
