hey all i just had my r32 dynoed at hyperdrive, when i bought it i was told it had about 299rwhp with a miss, i wasnt sure so i took it to hyperdrive this mourning with spitfire coils and only pulled 265.9rwhp at 14psi, the boost was all over the place, the guy at hyperdrive told me the hks 2540 wont really do anybetter than that :D so anyway im gonna get a new turbo, any suggestions where to take it or what turbo to get??
cheers
Edited by sidewayssam
https://www.sau.com.au/forums/topic/200757-slydr-just-been-tuned/
  • Replies 90
Posted Images
i recommend the HKS GT-RS i think brand new from www.greenline.jp is 2.5k give or take...i've been in [Michael]s car and damn its responsive and powerful hahah or even the Trust TD06-25g or 20g but i would go the HKS because its coolant and oil cooled the Trust turbos are only oil cooled also the Garret GT30 series they good to hehe :D
cheers
i was under the impression the 2540 were good for 300rwhp + ?
Edited by showbizz
hey all i just had my r32 dynoed at hyperdrive, when i bought it i was told it had about 299rwhp with a miss, i wasnt sure so i took it to hyperdrive this mourning with spitfire coils and only pulled 265.9rwhp at 14psi, the boost was all over the place, the guy at hyperdrive told me the hks 2540 wont really do anybetter than that :blink: so anyway im gonna get a new turbo, any suggestions where to take it or what turbo to get??
cheers
Nothing wrong with the 2540. As people have said it will net upto 350 or so and will run 18psi.
What ecu are you running on the Rb25?
yeh its a rb25det mods are as follows
rb25det
block acid washed, bored 0.5mm, torque plate honed
crank polished and deburred
GTR rods shot piened, resized and fitted with arp rod bolts
all balanced with new flywheel and clutch
arias forged pistons and rings
acl race series crank bearings
adjustable exhaust cam pulley
hks gt2540
walbro 400hp fuel pump
550cc injectors
apexi power fc tuned by xspeed
hks evc waste gate controller
spitfire coils
new ngk plugs
k&n pod filter
z32 afm
aluminium fmic
3.5inch jap exhaust with apexi muffler
Your setup will make a very easy 350rwhp if it really is a 2540.
Topracing is open this coming Monday but as we closed for 3 weeks the backlog is quite big so best ring John about booking anything.Its the time of the year we build new racecars and refresh/upgrade the current ones so it may be tough to get in for anything other than small jobs.
Damn you're only making 20hp more than me and all I've got is a stock 25 turbo! same dyno too.
I've got a GT35R with a .82 rear housing waiting to go on my engine.. I reckon it should chirp 2nd :blink: would suggest either a GT35R with the smaller .63 housing or a GT30 for your engine. Pick a hp goal and have a read through the 25 turbo upgrade in the FI area.
so do you think it is just a case of upping the boost and retune?
wow is that all.. i'd be pretty pissed at tha guy who sold u it huh!!!
i'd feel sorry for u =P i got 268hp @ 10psi stock everything nearly!!
got a new engine since =P hyperdrive have gotta do my timing its 15o out =/
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
