I think the brand is Brewers Choice (it comes in a 1kg plastic bag)..
But I've also had the Coopers brand one and it's the same stuff.
$3.50 is what I think it was..
actually, I'll go do woolies today at lunch to get a bag as I've only got enough left for a week.
Post a pic of the one I mean after lunch.
Would this stuff be good to take as a pre-lifting carb load?
Pre-lifting carb loading using sugars doesn't really make sense to me. You want carbs/proteins that will last through your workout :)
oops, misread something. I think I've got 2 posts mixed up, coz you're completely right lol
Is anyone here taking a dextrose supplement for their post-workout shake? I've been doing a bit of reading on it and it seems like something you could really benefit from.
Yea I take it, the brand is international protein and they call it extreme carbs... Seems to be working, makes u feel really full as well so I can't eat dinner for an hour or two after taking it.
Pretty much replenishes glycogen levels and helps with recovery... Just full of complex carbs which is what u want straight after training, absorbs really quick too
These are the 2 posts I read, and I think I've muffed up when I saw "complex carbs" which is what I thought was recommended pre-lifting (1.5hrs prior)
Ask anyone who's ever had lower back pain, how debilitating it is, and how scared they are to engage in an exercise like deadlifting for fear of aggravating things. I normally skip this one and work around it by doing other exercises that compliment my lower back muscles; I always figured it's better to be safe than sorry, considering how many exercises depend on good back health.
Lately the back pain has been getting better - I've been sitting more upright at my work desk and I changed my mattress for something more supportive. Still not sure if this is the cause, there's nothing worse than not knowing the exact cause of a debilitating pain, because you don't know what variable to take out of your life or exercise routine.
Regardless, I have been feeling better, and lastnight at the end of my gym session I thought I'd take a roll of the dice with some light deadlifts to finish it off. ~70kg, nothing to brag about and only a few sets of it, but enough to activate muscles for the first time doing an exercise. I feel great today...lower back is sore like I've been humping all night, but it seems to be the good kind of pain, the muscle-broken-down kind of pain, rather than a joint pain. I might continue doing it lightly over the next few weeks and see how things go...
I recently found a (better) chiro if your looking for one.
He's a long drive for me, but worth it. He's also a powerlifter so he knows exactly what to look for in terms of muscle development in the back et cetera :)
Can you PM me the details? I wouldn't mind getting checked out to see if anything is out of whack...my first call when I got the lower back pain should have been a visit to an osteo or chiro...
someone ran into the back of me playing basketball and put my neck out the other week... I ignored it (neck was a bit stiff but nothing extreme) and went to gym anyway... a bunch of heavy powercleans and overhead presses later my whole neck/upper back had locked up and was damn painful, I couldn't even turn my head... off to my Osteo I went and after some work it was heaps better... did a very light gym session and lots of stretching and then went back and saw him again... after he did some more work I did another gym session and its now 100% again
he was very impressed I had been to do gym sessions and lots of stretching between seeing him... said my recovery was better for it... as long as your not stupid about the weight, resistance training for injured areas is as important as stretching... I also like to use hot water bottles and Arnica cream for the inflammation
I've also heard lots of good stuff about foam rolling but have never tried it
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
