How much of your 22kg gain would you estimate to be muscle?
It's very, very hard for me to gain weight as it is (being an ectomorph) so i've always had a fairly low BF% , but I'm not gonna lie, I've gained a slight bit of chub around the lower abs. I'm also only 18 so it would have been some natural growth gains in there, but most of it is muscle. My girth measurements around the waist however didn't change too much, originally 29 inches (small waist, epic V in the making lol), up to 33, now back down to around 29-30 while maintaining the weight (came off of the dirty bulk and opted for a cleaner bulk recently). In response to "if it was that quick everybody would do it" , it's really not that impossible to achieve with focus on compound lifts, very little cardio, and a dirty bulk focusing on carb loading and at least 200g of protein per day. It took me just about 15 months (60 weeks) to gain 22kg, which is around 1.5kg a month. Compare that to steroids or HGH supplements where many people gain 10-15kg in one or two cycles (8-10 weeks max) and suddenly you can see it's not fiction.
Now back on to the dirty bulk for this winter, aiming for 90-95kg by the end of the year (although my gains will start slowing) and then I'll lean out to around 90kg. Set your goals high thumbsup.gif
Good way to find out is by getting a DEXA scan (essentially an x-ray with body composition results).
It's good to get a benchmark figure before you plan on doing a particular routine for the year for example.
I got one done in Sydney at MeasureUp (was $85 for just the scan or $150 for a consultation) but there's one in Hawthorn for you Melbourne boys as well.
Sydney - MeasureUp
Melbourne - BodyScan
I ended up being 13.3% body fat, which I was reasonably happy with, but room to improve...
It'll tell you individual mass and composition of limbs as well. Scan itself took about 5 minutes flat.
Nice! Thanks for the link. Always wanted an accurate measure of BF and the individual limbs part sounds good. Well worth it!
No worries mate. Yeah I usually use one of those electronic scales (which are notoriously inaccurate but okay if using for longitudinal measurements to track fat % over time), so went home that day and got a measurement off my scales so I could say "13.3% via body scan = 19.0% using POS scales". Then I might be able to apply that ratio in future.
I gotta say, after doing some cutting, you look at yourself and see some abs coming through and go "I'm never letting these disappear again".
Only to go and polish off a bag of chips a few hours later >_<
lol yeah abs are addictive. Good motivators to stay trim and healthy, but I can't knock back a whole bag of chips once in a while. Consequently, I'll never be shredded, but I'm pretty happy with my stomach :)
lol what's with all the sweat talk? in other news, anybody have some tips on how to not lose weight during illness? I've had two gainer protein shakes today (50grams protein, 70grams carbs per serve) already, and plan on having another before bed. May be overkill, but i'd rather overdo it than under-do it. P.S. Eating solid meals is ridiculously hard
Damnit, just wound up in the same boat as you - only I'm getting shafted harder.
TONSILLITIS I f**kING HATE YOU!!!!11!!1!one!!11
Tried drinking gargling water with a bit of salt in it? Don't overdo it as you'll dry out your tonsils too much and cause more irritation, but the salt will draw out some of the water and crud that has built up in your tonsils and reduce the swelling a bit.
Yeah I've always done that with throat irritations, though the swelling and pain makes it very difficult to do right now. I did it with just normal water and nearly choked haha. Will give it a shot shortly though.
Percentages don't matter anyway. If you are happy with the lean you are then it's all good. Being 'ripped' is a relative term.
eating chips ,drinking pints and still having visible 8 pack abbs means more hard work...ha ha..
Downlights behind a mirror or standing side on to the sunshine in the reflection of a car window :whistling: can help too...lean is indeed all relative. And I'll never give up the snacks lol.
Body builders look "good" on stage because they've tanned, greased, dieted and dehydrated themselves to death over the last day or so. When you see them outside of competition, whilst still large in stature, it's amazing the difference between the two forms. In pro bodybuilding there can be as much as 15kg difference between on-season and off-season.
Still, we can't deny the solidity of statistics...if nothing else, the baseline is good for monitoring your progress. And it's not as if the mirror doesn't lie to us from time to time :cheers:
haha I do this! still I'm not as lean as you... all photographic 'techniques' aside looking good... nohomo :cheers:
In the right light I've got the top 4 in now... but I'm also pretty hairy so sure if a shaved it would better for seeing definition but I CBF going that far... shit gets all itchy and annoying when you shave it... I'm rocking a beard at the moment as I CBF even shaving my face lol
LOL Troy, I have to make up for the fact I don't have a build thread :P
Forgot to mention shaving as a technique for bringing out definition...and once you shave, you don't go back...do it Nick ;)
lol there's a lot to shave :blush: I clipper it nice and short but never gone the full razor treatment
I kinda like being called chewbacca or manimal lol... plus when you have a tan and obviously work out, being a bit hairy stops people from thinking your auditioning for Jersey Shore!
haha definatly a rarety birds
any idea what percentage body fat u are?
not that it really matters, as long as your happy with what u see in the mirror..... or car window :thumbsup:
No clue, that's one of the reasons I want to get a bodyscan done. I'm 188cm @ ~80kg with something of a narrow bone structure, if that gives any indication. And yeah, I'm 99% happy with what I see...you'll never be 100%, but you can get pretty damn close I reckon :thumbsup:
How's your cutting going?
well youd have to be under 10% i reckon.. maybe closer to 7-8. results will be interesting
gettin there mate, bout 90kg atm... i dont really have a goal which is probably not a good thing
ideally id like to keep as much lean mass as possible.. even try and put on some lean mass if i can
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
