The problem is I don't know what is exactly wrong so am trying different things based on the opinion of therapists.
If the answer is squat more then I must be squatting too much for my core strength at the moment which seems odd as my legs want to squat plenty more.
So I either lower the weights or work on some specific exercises to target a supposed weakness and if nothing else prove to therapists that my core is fine (if it is).
Anyone had good experience with Chiro's?
Woodchops are good for three dimensional core strength and people shooting for aesthetics. The former being useful for preventing injuries in other exercises due to imbalance or improper technique, and sports that require quick turning of the upper body (boxing for example). Being a side to side movement, they engage some muscles that are seldom worked hard during linear up and down movements. They will work your abdominal wall, your obliques, your pectorals, your shoulders, your lower back and even your legs. Be wary of going heavy if you have lower back or shoulder problems though - it's not exactly a natural movement of the body.
3 months of woodchops and a low enough BF% =
You really want to be doing squats and deads a lot though...there's no substitute for the core strength these exercises give you.
yeah. Chiros have their place even though physios don't think so.
it's an odd feeling when they adjust you and kind of scary.. but it does help. It's pretty temporary but after multiple visits, the adjustments they make seem smaller so it does help.
My spine is a little crooked, and my hips slightly tilted (right leg is 6mm shorter than left).
The chiro I went to was quite good. he was all about adjust, 10 minute walk, then ice it for 10 minutes 3 times a day and no load on it.. This was after my initial injury.
first week of the injury I saw him 3 times, 2nd - 4th week I saw him twice each week, 5th and 6th week I had single visits.
he'd find the spot, move you back, forward, side to side while feeling the spot to see if it moves properly or binds, and adjust (which is crack basically, beit via a twist or push), then walk, then ice.
6 weeks later I started doing squats and deads again as he suggested.
went back 2 times about 6 months later for adjustments and that was it.
There are different type of chiro practice too.. can't say what is better.
maybe research that if you want.
That type of toothpaste is shit Birds, you have to hack it open to get the last quarter.
Yeah fair enough I realise doing those compound lifts is a winner and it IS my desire to do them, I just want to try and lock down what my back issue is before I continue adding weight to avoid further issues.
It's either caused by my leg issues OR was caused by poor form/weakness when I started doing the lifts, as we all know I was dodging them.
Problem is I started regular walking and these compounds lifts around the same time (I think) so hard to isolate.
At the very least it doesn't specifically hurt when I do those movements, only after. Also, despite having not gym'd since Friday it hasn't improved but I have still been walking twice daily (now with basic insoles and my arches strapped up).
Aids.
I can't get that low even with a wide stance and well above 45 degree angle on my foot position.
The scar tissue on my ankle doesn't allow it. I can get probs 65-75% of the way there if I try and thats pretty uncomfortable. Still below parallel though.
My vid shows a semi comfortable depth for me, but doesn't show what I consider improved setup and tension in my core before I start the motion.
Aids.
I was thinking something similar , but thought maybe it was moisturiser...
Hack squatting or leg press might put less strain on your ankles?
Went to a chiro for a while, he was a good one as well (did xrays at the start, talked me through analysis on the comp screen etc) but after a while got the feeling that the adjustments were not doing that much and seemed like there was a gameplan geared to get me going back there until the end of time, i.e. no defined end point.
you forgot but still suggested he does ATG
I didn't know about the big L. And I was saying that Olympic stance is easier to get your ass to the ground, which it is.
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
