The problem is I don't know what is exactly wrong so am trying different things based on the opinion of therapists.
If the answer is squat more then I must be squatting too much for my core strength at the moment which seems odd as my legs want to squat plenty more.
So I either lower the weights or work on some specific exercises to target a supposed weakness and if nothing else prove to therapists that my core is fine (if it is).
Anyone had good experience with Chiro's?
Woodchops are good for three dimensional core strength and people shooting for aesthetics. The former being useful for preventing injuries in other exercises due to imbalance or improper technique, and sports that require quick turning of the upper body (boxing for example). Being a side to side movement, they engage some muscles that are seldom worked hard during linear up and down movements. They will work your abdominal wall, your obliques, your pectorals, your shoulders, your lower back and even your legs. Be wary of going heavy if you have lower back or shoulder problems though - it's not exactly a natural movement of the body.
3 months of woodchops and a low enough BF% =
You really want to be doing squats and deads a lot though...there's no substitute for the core strength these exercises give you.
yeah. Chiros have their place even though physios don't think so.
it's an odd feeling when they adjust you and kind of scary.. but it does help. It's pretty temporary but after multiple visits, the adjustments they make seem smaller so it does help.
My spine is a little crooked, and my hips slightly tilted (right leg is 6mm shorter than left).
The chiro I went to was quite good. he was all about adjust, 10 minute walk, then ice it for 10 minutes 3 times a day and no load on it.. This was after my initial injury.
first week of the injury I saw him 3 times, 2nd - 4th week I saw him twice each week, 5th and 6th week I had single visits.
he'd find the spot, move you back, forward, side to side while feeling the spot to see if it moves properly or binds, and adjust (which is crack basically, beit via a twist or push), then walk, then ice.
6 weeks later I started doing squats and deads again as he suggested.
went back 2 times about 6 months later for adjustments and that was it.
There are different type of chiro practice too.. can't say what is better.
maybe research that if you want.
That type of toothpaste is shit Birds, you have to hack it open to get the last quarter.
Yeah fair enough I realise doing those compound lifts is a winner and it IS my desire to do them, I just want to try and lock down what my back issue is before I continue adding weight to avoid further issues.
It's either caused by my leg issues OR was caused by poor form/weakness when I started doing the lifts, as we all know I was dodging them.
Problem is I started regular walking and these compounds lifts around the same time (I think) so hard to isolate.
At the very least it doesn't specifically hurt when I do those movements, only after. Also, despite having not gym'd since Friday it hasn't improved but I have still been walking twice daily (now with basic insoles and my arches strapped up).
Aids.
I can't get that low even with a wide stance and well above 45 degree angle on my foot position.
The scar tissue on my ankle doesn't allow it. I can get probs 65-75% of the way there if I try and thats pretty uncomfortable. Still below parallel though.
My vid shows a semi comfortable depth for me, but doesn't show what I consider improved setup and tension in my core before I start the motion.
Aids.
I was thinking something similar , but thought maybe it was moisturiser...
Hack squatting or leg press might put less strain on your ankles?
Went to a chiro for a while, he was a good one as well (did xrays at the start, talked me through analysis on the comp screen etc) but after a while got the feeling that the adjustments were not doing that much and seemed like there was a gameplan geared to get me going back there until the end of time, i.e. no defined end point.
you forgot but still suggested he does ATG
I didn't know about the big L. And I was saying that Olympic stance is easier to get your ass to the ground, which it is.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
