Did my full sets fiddling with heigts then thought I'd do a few more reps at the end and record.
This is probs where I felt most comfy, I was initially standing straighter.
Thoughts?
http://youtu.be/uf_XgacRYE0
hahaha nice work Boz :P
I did bench press this arvo for the first time since the beginning of March...my previous working set was 85kg for 5 reps at that time, and had a 1RM of 95kg. This arvo I only did 1 set (for a laugh to see if I could even do 1 rep) - 100kg, managed 5 reps.
f**k yeah DB press lol
Yeah Pendlay are too low and hard on my back at the moment.
As it was, in that vid it was harder than normal for me as I'd normally be straighter maybe 50-55, so if that lean is a good lean in the vid then I'll have to maybe lower the weight and re-set form in that exercise, which is fine.
I'd be inclined to say that even after only 3 sessions of trying to DL from the floor, my SIJ discomfort has lessened, could be a coincidence but we'll see.
Nice work Troz!
Edited by ActionDan
Yay Troy!
:) cheers guys! Haha. I know it isn't much, especially compared to those currently smashing out PPP, but it certainly blew me away lol
It's good Troy! Hey, mine isn't much!!!!! but I was really happy with my increase on Friday :) Edited by L33SH
saw my first squat rack curler today, though our gym had 2 EZ Curl bars and weighted barbells specifically for that purpose which were not being used lol. Also saw smith machine deadlifts that looked hella uncomfortable.
Gymbros continue their compound dodging antics, so ended up deadlifting by myself today - I take it that it's normal to scrape the shit out of your knees and shins when doing it properly?
There's a correlation between leg scrapage and doing it properly.
That being said, some of the big lifters around the world don't scrape their shins, so everyone does it differently. Most do find it easier the closer it is to the body.
Easily. The body will slip into ketosis and convert fat into ketones which the brain and heart find easier to use. This is why there are positiv aspects. You can do the same by restricting your carbs to less than 20g per day. There is ZERO need for carbohydrates in the human diet as the body can produce what it needs by way of glucose from gluconeogenesis in the liver. This amounts to roughly 100g per day for the brain, then slowly reduces as the body become more keto adapted. In fact, not eating carbohydrates and increasing your fat intake is an excellent way to lower cholesterol. Ive been carb free for 1.5 years and my triglycerides are down to 71 from 252. I have the lipid profile of a 6 month old at 33.
I bet this guy is fat or skinny. Just a feeling.
If he doesn't lift, then he's definitely going to be skinny. Why do you deny human nutrition facts so often? lol
Not saying it's better, since keto is hard to deal with and f**king sucks for digestion sometimes, but he's more or less correct. Our bodies don't NEED carbs to function, it just makes things a lot easier if we do have them....and there are health benefits to restricting carbs big time like that, though from a weightlifting perspective it makes things VERY difficult I find.
Should point out that I'm not disagreeing with his information/science; he just sounds like one of those people who has gone and spent hours, even days studying up on the science behind a particular diet (Lipids of a 6 month old? Really? That's the figure we're looking at now, instead of kg?) instead of devoting that time towards lifting some weight and not eating so much shit.
People just always looking for the alternative, easier way out of doing hard work...this mentality doesn't go hand in hand with success. It makes you good at failing.
Probably blow that guys mind that on Saturday I ate pig on a spit, about 3 bags of chips, crackers and cheese, many chocolates, ice cream, wheat based cereal and a metric shit ton of bread. And I won't see an ounce of it hit my bf%. His lipids can suck my dick.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
