Did my full sets fiddling with heigts then thought I'd do a few more reps at the end and record.
This is probs where I felt most comfy, I was initially standing straighter.
Thoughts?
http://youtu.be/uf_XgacRYE0
hahaha nice work Boz :P
I did bench press this arvo for the first time since the beginning of March...my previous working set was 85kg for 5 reps at that time, and had a 1RM of 95kg. This arvo I only did 1 set (for a laugh to see if I could even do 1 rep) - 100kg, managed 5 reps.
f**k yeah DB press lol
Yeah Pendlay are too low and hard on my back at the moment.
As it was, in that vid it was harder than normal for me as I'd normally be straighter maybe 50-55, so if that lean is a good lean in the vid then I'll have to maybe lower the weight and re-set form in that exercise, which is fine.
I'd be inclined to say that even after only 3 sessions of trying to DL from the floor, my SIJ discomfort has lessened, could be a coincidence but we'll see.
Nice work Troz!
Edited by ActionDan
Yay Troy!
:) cheers guys! Haha. I know it isn't much, especially compared to those currently smashing out PPP, but it certainly blew me away lol
It's good Troy! Hey, mine isn't much!!!!! but I was really happy with my increase on Friday :) Edited by L33SH
saw my first squat rack curler today, though our gym had 2 EZ Curl bars and weighted barbells specifically for that purpose which were not being used lol. Also saw smith machine deadlifts that looked hella uncomfortable.
Gymbros continue their compound dodging antics, so ended up deadlifting by myself today - I take it that it's normal to scrape the shit out of your knees and shins when doing it properly?
There's a correlation between leg scrapage and doing it properly.
That being said, some of the big lifters around the world don't scrape their shins, so everyone does it differently. Most do find it easier the closer it is to the body.
Easily. The body will slip into ketosis and convert fat into ketones which the brain and heart find easier to use. This is why there are positiv aspects. You can do the same by restricting your carbs to less than 20g per day. There is ZERO need for carbohydrates in the human diet as the body can produce what it needs by way of glucose from gluconeogenesis in the liver. This amounts to roughly 100g per day for the brain, then slowly reduces as the body become more keto adapted. In fact, not eating carbohydrates and increasing your fat intake is an excellent way to lower cholesterol. Ive been carb free for 1.5 years and my triglycerides are down to 71 from 252. I have the lipid profile of a 6 month old at 33.
I bet this guy is fat or skinny. Just a feeling.
If he doesn't lift, then he's definitely going to be skinny. Why do you deny human nutrition facts so often? lol
Not saying it's better, since keto is hard to deal with and f**king sucks for digestion sometimes, but he's more or less correct. Our bodies don't NEED carbs to function, it just makes things a lot easier if we do have them....and there are health benefits to restricting carbs big time like that, though from a weightlifting perspective it makes things VERY difficult I find.
Should point out that I'm not disagreeing with his information/science; he just sounds like one of those people who has gone and spent hours, even days studying up on the science behind a particular diet (Lipids of a 6 month old? Really? That's the figure we're looking at now, instead of kg?) instead of devoting that time towards lifting some weight and not eating so much shit.
People just always looking for the alternative, easier way out of doing hard work...this mentality doesn't go hand in hand with success. It makes you good at failing.
Probably blow that guys mind that on Saturday I ate pig on a spit, about 3 bags of chips, crackers and cheese, many chocolates, ice cream, wheat based cereal and a metric shit ton of bread. And I won't see an ounce of it hit my bf%. His lipids can suck my dick.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
