Powerlifting gyms are extremely rare. That one in Mildura is a PA affiliate gym, I dont know of any really strong guys training there, going by results on the PA website.
Looks like there will be a PTC opening in Eltham shortly. The owner has an extensive background in powerlifting and strongman, plus was a previous gym owner.
Still too far bozo lol
I live in Eltham. More info please :)
Unfortunately health and fitness being an "only get out what you put in" thing, is prone to the energy conserving / lazy nature of organisms in general, i.e. path of least resistance.
If there's an option promising people good results for less work, they'll take it...hence demand for such bullshit.
I must have come at my reps question wrong, let me try again.
What supplement or how many calories do I need to improve my rep range for a given weight.
Trenbolone.
But no seriously (I didn't read anything earlier), just eat more. Chuck in an extra meal. Have another coffee or something just before your workout. EAT EVERYTHING.
Maybe just have a binge day or something lol
This was the question.
"What methods have you guys successfully used to increase reps for a given weight.
Using bench as an example, I'm out of plates and have no room for more on the 7ft bar anyway (lots of small plates). There's 116kg all up inc the bar (8kg standard 7ft bar).
I can buy more plates I know, but in the meantime I'm not seeing improvement in rep count at this weight.
I'm doing a 3x8 routine which looks like this at the moment.
First set lighter 93 (8) 116( never more than 7, I often get half way up on the 8th rep attemp but can't make it without a spotter and I train alone) then on the final set I'll get 4-5 reps tops. I've added 4th and 5th sets before, but I'll get say 4 reps on the next set then 2 or 3 on the last. I've also tried increasing the rest from 2 to 3mins etc.
I'm eating more protein, doing no leg work at the moment so am plenty fresh (normally I'd have done squats before bench) but just not seeing the 8th rep appear in that second set or any more than 5 in the last.
As I've mentioned before, normally I'd add weight earlier and over time, if you drop back to the original weight you struggled on you find you can do the reps now.
But without room on the bar or more plates around, what other techniques can I try? "
As you can see Troy I am eating, and I'm seeing some of that appear around my waist so I'm eating enough =\
ah, hmm.
Maybe a weight reset with increased reps is on the cards? Perhaps drop it back to 80kg or something, and aim for 50% more reps than usual, and work up from there. I mean this should be guaranteed to work, just maybe not the most efficient or optimal method (since really I haven't a clue haha)
Yeah possibly.
I considered dropping to 100 and going sets of 10 if I could manage it, but I think to carry over to 16kg higher and 8 reps it would need to be sets of 15 or something instead.
To get up the reps at that weight as I can't add more to the bar (no more plates and no space on the bar) plus the bench I have is rated to 200kg, and I'm already over that a touch.
Ideally, to be able to do at least 2 sets of 8 at that weight, using the first set at a lighter weight to loosen up/make sure everything is right. I've added another set before to get the missing reps but that's not the same as doing 2 sets of 8 continuously.
Edited by ActionDan
First set warmup 60kg or less (doesn't matter if it's super light). It's a dynamic stretch. Do 10-12 reps tops.
You will get 2x8.
I'm just saying, in terms of total volume moved.
If I go 60x8 116x16 (in 2 sets)
That's 2336kg.
Currently it's
88x8 116x7 then 116x5 or so
For 2096kg.
If you didn't count the first set at all as it's warmup (an I could actually get the 116x8 x2 out) I'd still be in front.
My goal was to rep in the 120 range, but I'd need some plates for that, which I might get as the long term squat and DL goal will need them anyway (when I can finally get back into leg stuff).
Total volume weight is a poor comparison across hugely varied weights...lifting 20 of 50kg has more volume than 2reps of 200kg...I know which would build more strength/muscle!
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
