I only do 2 body parts per visit eg Monday chest and bi's, Tuesday Back and Abs, Wednesday Rest, Thursday Shoulders and Tri's and Friday Legs ( Shudder ) I usually do 3 sets of 8 than 3 sets of weight where im failing before 6. I usually do a min of 3 different exercises for each area.
I should add that I am currently bulking and am not doing any cardio. ( also as I typing this Im eating chicken and sweet potato :)
Edited by Kenna802
Not if you're only doing 2 or 3 exercises in the session.
I only do two or three exercises in about that time but way less volume, two unfit for that shit haha
Ah fair enough, love sweet potato. Chicken and rice with some guacamole for flavour is nice too
Damn that's fast for that amount of volume
With volume training, as you're not always lifting extremely heavy weights / at your max, you can usually shorten your breaks and pump out lots of reps. It does tax the heart and lungs if you're not used to it, though; your head will certainly spin! My diet isn't fantastic; the volume training burns through calories and keeps me trim.
Also, Leesh, when I do 2-3 exercises it only takes me 45 minutes. If I was doing your workout I would be done in an hour or just over.
Well aren't you good
Fair enough, higher volume is something I might look into next year once I've hit some of my current goals
did my 1RMs today with my gym bros - a couple of months since I stopped doing bro splits and did the PTC beginner routine. Squat 200kg, DL 170 (one half assed rep at 180 but IMO it dosen't count), Bench 110kg. Weight loss has slowed down (now at 115kg, about 1kg per month), but very happy with my strength gains. I probably could have pushed the squat a little harder, but was not sure about my knees. No wraps, belts or gloves etc, only chalk.
Working on a 120kg bench and 200kg deadlift by the end of the year.
Interestingly my bro split mates were benching 150, but couldn't keep up with squats and only just managed to keep up with deadlift. I reminded them (like I do all split devotees), that squatting is so much easier when done 3x a week.
well everyone always complains about how sore they feel after 'leg' day, or squats day; I found that squatting 3 times a week means that I never have severe DOMS in the quads, glutes or anywhere else for that matter.
Oh I see. I don't get sore from squats anymore because I cant go heavy cos of knee bending in
Give it a shot and see if you like. Good for those who like a mental slog.
This. I don't get doms either unless its after returning from a week or two off...tomorrow for example
yeah my right knee caves in as I'm coming up from the squat
It's causing a hamstring strain too
weak adductors apparently
My adductors were pretty sore for the first few weeks of squatting 3x week, It went away and so did my knee bend. Might be a correlation there but given the amount you squat it would feel like doing a weeks worth in one session.
Most likely will once I reach my goals, not sure how long that will be, next year sometime hopefully
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
