Ye I got the apple raspberry. I'm quite tolerant to pre-workouts and caffeine in general so we'll see how it goes.
Cool. The first few times I took it I had trouble getting to sleep at night, then I was fine.
Finally getting closer to pre-injury deadlift numbers. Managed 162.5kg x 4 tonight, no chalk or straps or belt. Felt really good, didn't have to grind too much either, so quite happy.
Bulkpowders.com.au do a supplement called "Thermocut".. Since I'm pretty sensitive to caffeine these days, I can't do pre-workouts. However 2 caps of these land 40mg of caffeine; enough of a boost to get focused. My training partner seems to like it better than his pre-workout, says the lesser 'buzz' feeling actually helps with the focus.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
