good to hear u got through mate
Obviously coilovers, lowered slightly, airpods, wheelspacers, Kakimoto Dual N1 exhaust & BBS wheels with 265 rubber are all OK as long as they're within spec and all mounted well.
lol, no they arnt. a cop shop inspection isnt very thorough, they will check whats on the defect, and depending on how lucky u are they might have a suss of other things. but just for future reference:
coilovers are legal providing they are not height adjustable, although by the way u said that it makes me think they were. even if they are at legal ride height they arnt legal if they are able to be lowered below or above the legal limit.
pod filters are legal in SA providing they are secured. wheelspacers are illegal unless fitted from factory, aka pretty much not legal for any car. exhaust might pass, probably borderline. 265 tyres indicate probably a 9" wheel knowing BBS, 9" wide is illegal, it gets more technical with regards to how it affects track, but basically they are illegal.
so count urself as pretty lucky, saying that i have passed cop shop inspection with straight through exhaust etc, they just checked what they needed and ignored the rest.
lol you took it down on the right day
41deg and all they want to do is sight it "Yes thats a car lets go back in side now" ;)
well done man
Yeah, I think you're both right. The shed at Sturt was about 50 degrees inside while the small office was air cond. While the one inspector (by himself) isn't inspecting, he sits in the small office and it was 10 minutes before closing time so I think he had enough for the day. He did ask to put my windows up 1/2 way so they are interested in things like tint and possibly anything else very obvious.
Wanted to stay low mount so I've already bought a pair of GT2860R 707160 -5.
No point in going top mounts or big single unless it sees the track or drag strip more than the street.
even then ya would'nt go high mounts or big single unless your looking for lots of lag and sub 9 sec times. GTR's were designed for low mounts and perform better in most areas if left that way.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
