hey all,
im not sure if my car is running as well as it should b....
138XXX kms, simon did my oil filter/oil change, new belts, new plugs, coolant flush done not long ago. looks as of the timming belt and water pump was done not long ago but should get it redone so im "sure" its done.
needs new:
castor rod bushes, new hoses, new radiator (as begun to corrode), def needs a paint job, front bumber scratched a lil and not fitted properly, wheel alignment, new tires.
it idles quite rough and 1 of the belts slips when i start her up.
im up for spending money on my car but i dont want to spend the amount i paid for it on making it run 100%..
im after advice and opinions...
cheers peps.
https://www.sau.com.au/forums/topic/200880-when-to-cut-your-losses/
As one of the older members of SAU, can I pass on some advice on life"
If its got tits or wheels its going to cost you a lot of money.
From what you have listed, if its going to cost moire than 2k to fix it may be cheaper to sell it and buy another one (but check it out this time so you dont end up in the same situation again)
+1
With hindsite I wouldn't have bought my 1989 R32 GTRs and just sat on the cash in 2003 until now where I could've bought an 2002 R34 GTR V Spec II Nur or M Spec Nur for nearly the same money I've spent on my R32.
+1
WOW....you've spent some $$$$ by the looks of things.
Last time I checked prices of good low km 2002 NUR (very rare) they were still pulling about 100k or more.
WOW....you've spent some $$ by the looks of things.
so u think id b better off selling up and buying a R32 gtr?
how much do 32 gtrs go for these days? around 15-18k?
+1
that's coz u had 2 32 GTR's
(come on MSN more)
I have spent alot but not $100k... yet!
And 2002 R34 GTR V Spec II Nurs can be bought in Japan right now from 4,980,000 - 7,180,000 Yen (AUD$51,710 - 74,554) + shipping, customs, import tax, compliance etc. I have spent in between those amounts and still going... :);):(
Edit: Original link didn't work. I grabbed these prices from Goo-net
http://www.goo-net.com/english/
Edited by writeoff
If $ are a consideration then I would recommend staying away from GTRs, especially 15-18K GTRs. GTRs eat money... like Pac Man. Really! Ask anyone whose has owned one for 12 months or longer.
(come on MSN more)
If I added up both GTRs then I would be close to the $100k mark. I was referring to the grey garage ornament I have with a GTR badge. The white one has had a new owner for some time now.
That would be about right for a Grade 4.5 or 5.0 with an A interior.....and dont forget GST with import tax being calculated on top of the GST inclusive price (or maybe the other way around).
Customs isn't much but compliance is about $4000 + tyres, freight about $1000 but for a car like that you would not go 'roll on roll off', you'd pay extra for a container.......all adds up pretty quick.
You probably wouldn't want one anyway because if the cost of the car didn't kill ya the insurance would.
Had a look at a couple of Jap Auctions and found a couple 1993 BNR-32's Grade 4.0 with B interiors and between 50 to 70 kms for around 7 to 8 million Yen.
You would comfortably land a good one for between 15 -18k based on those figures.......then again there should be a few good ones already in the country, just depends how urgent you need a good one.
Trust me I know the prices of bringing them over and getting them through Regency and then getting all the goodies refitted. It was alot more than the cost calculators at J Spec or Prestige predicted.
Insurance isn't so bad through Shannons with >30yo, rating 1, multiple policies, and limited km.
What sites are you using as I like to keep an eye on the market and look to see if a M Spec Nur or 400R come up for sale?
castor rod bushes -always need replacing on all r32's, often
new hoses, new radiator (as begun to corrode) - age related, once per 10 yrs
def needs a paint job - cosmetic, not required
front bumber scratched a lil and not fitted properly - cosmetic, can be done same time the paint job is done
wheel alignment, new tires - a result of having poor castor rod bushes ;)
cheers peps.
regardless of the amount u spend, it'll be the exact same cost and the exact same sort of stuff that goes wrong... perhaps its more well spent on a gtr than a gts but apples and oranges...ive spent $6k on my gtr in the last 8 months and it was in a good condition when I got it. Truth is the 32's are getting long in the tooth and they need some TLC from time to time to keep em purring
-D
Sorry to whore this thread but I should mention that even though I have a 34, I really like the 32 GTR's and always have........so I'm abit biased.
They look very tuff and after all they are the original Godzilla that destroyed the Group A class about 15 years ago.
I'll try and shut up now.......sorry. ;)
I see the average R32 GTR price for something somewhat descent from $18k and over... anything less is generally a ticking time bomb if not a dud already.
If it's on the original turbos & hasn't had an engine rebuild then the turbos and internals will be 14-18 yo. Most will have had the boost turned up and are therefore running well beyond the original design of the car. I'd want one that had newish steel wheeled turbos and a proper engine rebuild preferably done in Australia by a well known workshop with a good rep that knows what they are doing. It's unlikely you would find these cars for less than $22k but I don't really check R32 GTR prices that often now so I could be wrong.
Here's just a few sites I used to look for mine but some of them require log in membership unfortuantely.......idirect.co.jp is one of my favourites.
http://www.japaneseusedcars.com/auction/auctions.htm
http://www.carontrack.com/nissan/index.shtml
http://www.monkys.jp/e/nissan_used_cars.htm
http://australia.autoterminal.com/online_auction.asp
http://www.idirect.co.jp/default.aspx
If you're talking locally, you're probably right.
If you're confident enough to get an agent to bid on one for you in Japan but bring it in yourself, you'll definitely get it alot cheaper.
Thanks. I only had 2 of these sites. I also use www.tradecarview.com
