I've seen it done on a RB a couple of years ago, personally i dont know why you would bother with a RB, for the money it would cost, you can get greater gains for less money with a good turbocharger setup. It is different however and pretty cool to see people doing something a little bit different.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3574748
i think when i look up supercharging on a skyline and read into it - it comes out expensive and lots of custom work
if you are a fabricator / mechanic then i think its fine - but for your average dude who just wants a bolt on kit turbo is easier and better $ for kw etc
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3574868
yehi was thinking maybe turbo and supercharged, like some rallycars, my engine is already turboed and rebuilt but yeh i was thinkn to do something a little bit diffrent
Ah ok. Yeah a twin charged setup would be a good setup however extremely expensive to do and set up correctly. Would be interesting to find out how much something like that would cost. Has anyone in Aus ever twin charged a RB25?
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3575494
yeah stockymcstock has done it he has a superchaged rb30det with a gt40
it looks like a complicated, lengthy and expensive process
do a search on some of his posts in the rb30 thread to find out what he has done etc
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3575501
This is one hell of a set up :rolleyes:
http://www.403drift.com/gallery/galleries/...14mph%20run.avi :)
and the site with the build
http://www.403drift.com/galleryview.asp?ID=11
not a 25 but a 26, I have seen it in person and what a monster. Now this motor is in a R32 GTR cant wait to see a run on the track with that.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3576175
I dont think its fake it is in the same spot as the one in town and just has dual turbos. They created less lag but rob your top end
Not true...kind off. If those superchargers are twin screw, then they will not limit the top end power at all.
As for the pic, its been discussed before, and that particular thread came to a conclusion that it IS fake. Fake or not, its crap coz there is not way you can fit all that in a skyline engine bay :D.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577095
ask stocky, from memory he said it wasnt worth it. its alot of time and effort for not much results, just get a correctly sized turbo, and with the leftover cash go RB30DET
that pic of the twin charge kit isnt fake either, i thought it was at first too because the pipin looks dodge, but i've got a pic of it from another angle, and from what i can tell its real
the only thing with that is with the way the piping is (from what i can see) the system wouldnt work, as they are booth running in parallel not series, and there doesnt seem to be any sort of valving in line either, think they just threw it together to try and look good lol
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577329
i love suprechargers, they are a great upgrade on an NA engine.. hell i would love to put one on my V35. a guy on WA had one on his V35 before he sold it..
but for an engine that already comes out turbocharged, like the rb, it just seems silly to bother going with the R&D of a supercharger when you can just bolt up a different turbo if you're not happy with power. that alone is reason enough not to bother in my eyes
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577449
Very well said. Pretty much sums it off perfectly.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577642
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
