I've seen it done on a RB a couple of years ago, personally i dont know why you would bother with a RB, for the money it would cost, you can get greater gains for less money with a good turbocharger setup. It is different however and pretty cool to see people doing something a little bit different.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3574748
i think when i look up supercharging on a skyline and read into it - it comes out expensive and lots of custom work
if you are a fabricator / mechanic then i think its fine - but for your average dude who just wants a bolt on kit turbo is easier and better $ for kw etc
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3574868
yehi was thinking maybe turbo and supercharged, like some rallycars, my engine is already turboed and rebuilt but yeh i was thinkn to do something a little bit diffrent
Ah ok. Yeah a twin charged setup would be a good setup however extremely expensive to do and set up correctly. Would be interesting to find out how much something like that would cost. Has anyone in Aus ever twin charged a RB25?
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3575494
yeah stockymcstock has done it he has a superchaged rb30det with a gt40
it looks like a complicated, lengthy and expensive process
do a search on some of his posts in the rb30 thread to find out what he has done etc
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3575501
This is one hell of a set up :rolleyes:
http://www.403drift.com/gallery/galleries/...14mph%20run.avi :)
and the site with the build
http://www.403drift.com/galleryview.asp?ID=11
not a 25 but a 26, I have seen it in person and what a monster. Now this motor is in a R32 GTR cant wait to see a run on the track with that.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3576175
I dont think its fake it is in the same spot as the one in town and just has dual turbos. They created less lag but rob your top end
Not true...kind off. If those superchargers are twin screw, then they will not limit the top end power at all.
As for the pic, its been discussed before, and that particular thread came to a conclusion that it IS fake. Fake or not, its crap coz there is not way you can fit all that in a skyline engine bay :D.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577095
ask stocky, from memory he said it wasnt worth it. its alot of time and effort for not much results, just get a correctly sized turbo, and with the leftover cash go RB30DET
that pic of the twin charge kit isnt fake either, i thought it was at first too because the pipin looks dodge, but i've got a pic of it from another angle, and from what i can tell its real
the only thing with that is with the way the piping is (from what i can see) the system wouldnt work, as they are booth running in parallel not series, and there doesnt seem to be any sort of valving in line either, think they just threw it together to try and look good lol
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577329
i love suprechargers, they are a great upgrade on an NA engine.. hell i would love to put one on my V35. a guy on WA had one on his V35 before he sold it..
but for an engine that already comes out turbocharged, like the rb, it just seems silly to bother going with the R&D of a supercharger when you can just bolt up a different turbo if you're not happy with power. that alone is reason enough not to bother in my eyes
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577449
Very well said. Pretty much sums it off perfectly.
https://www.sau.com.au/forums/topic/200998-supercharging/#findComment-3577642
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
