everything to do with doseing is a myth......everything that says its bad for the turbo is all theoretical. theres no actual proof that doseing (exsessive compressor surge) will shortn ur turbo life, i know many vls dosing day in day out at 18+psi and still survive longer then many skylines.
bring on the flaming but i think dosing sounds awsome.....not the dolphin dosing though.
this kind.
ignore the title cuz americans dont know f*kn shit. they think any sound from the engine comes from a HKS SSQ LOL
this kind.
its damn physics dude u spin something 100,000 rpm one way then reverse it in a second when its on bushings or bearings...... DUH its gonna do damage!
show us the proof then.
i have had many many engines over the years (non have blown up... i just have had a lot of cars) out of them only 1 had a BOV (my rb20) i do a lot of competition drift, and as yet have NEVER HAD A TURBO FAILURE from running no bov. I find that no bov makes for a much more responsive set up then having a bov.
the maths/physics says it bad, but wheres ther hard proof??
i have a turbonetics turbo i have not had a blow off valve working and i was running 14p the bearings r noisy and the turbo has heaps of shaft play ive had it on the car for 20000kms i see this as proof for me
many thanks and a very big thumbs up!
i have no hard proofe i just have common sence that all things wear eventually and turbos are one of those things... the principals behind a plumb back blow of valve help to keep forward momentum of the turbo and vent air to the intake to await throttle and spool up.....
no bov means backwards momentum (backspin) creating that dv tu tu tu tu noise because the air has on where else to go which means it would create more lag for the turbo to create forward momentum again.
this is my thoughts of common sence and theory anyway. tell me otherwise.
You are loading up the trust bearings on the turbo plenty. If other things fail before the turbo does that doesn't mean you aren't wearing it out faster or that there isn't instances of catestrophic failures in short periods. Turbo's that cop the abuse are doing so because they make them pretty well these days, not because there's no harm.
It's safe to assume turbo manufacturers know what they are talking about and we mere mortals don't.
From a Turbo Manufacturer (Garrett) website, one of a few refferences made on that site about the strain not having one introduces;
Blow-Off (Bypass) Valves
The Blow-Off valve (BOV) is a pressure relief device on the intake tract to prevent the
turbo’s compressor from going into surge. The BOV should be installed between the
compressor discharge and the throttle body, preferably downstream of the charge air
cooler (if equipped). When the throttle is closed rapidly, the airflow is quickly reduced,
causing flow instability and pressure fluctuations. These rapidly cycling pressure
fluctuations are the audible evidence of surge. Surge can eventually lead to thrust
bearing failure due to the high loads associated with it.
Blow-Off valves use a combination of manifold pressure signal and spring force to detect
when the throttle is closed. When the throttle is closed rapidly, the BOV vents boost in
the intake tract to atmosphere to relieve the pressure; helping to eliminate the
phenomenon of surge.
Here's an interesting one about compressor surge in general;
Surge is most commonly experienced when one of two situations exist. The first and most damaging is
surge under load. It can be an indication that your compressor is too large. Surge is also commonly
experienced when the throttle is quickly closed after boosting. This occurs because mass flow is drastically
reduced as the throttle is closed, but the turbo is still spinning and generating boost. This immediately drives
the operating point to the far left of the compressor map, right into surge.
Surge will decay once the turbo speed finally slows enough to reduce the boost and move the operating point
back into the stable region. This situation is commonly addressed by using a Blow-Off Valves (BOV) or bypass
valve. A BOV functions to vent intake pressure to atmosphere so that the mass flow ramps down smoothly,
keeping the compressor out of surge. In the case of a recirculating bypass valve, the airflow is recirculated
back to the compressor inlet.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
