i had an awesome time, definately keen for another one, i enjoyed cookin joey, cause we ate before anyone else, mwuhahaha
go cartin sounds fun, theres supposedly a place at arncliff? its like in a car park kind of thing an u can full drift an stuff :)
i'll try to find a link...
but yeah top day everyone, i'm glad u enjoyed it jeff...
p.s next time i think we bring toys for brad so he doesn't get bored an destroy everythin :)
  • Replies 607
Posted Images
Second that!! Thanks for cooking Paul you did a good job and definatly need something for Brad next time lol poor snag!
Second that!! Thanks for cooking Paul you did a good job and definatly need something for Brad next time lol!
That kart place looks good too..will put it to a vote against the others
This is all I can find..Minto karts don't have a website :P
http://www.hotfrog.com.au/Companies/Fastla...-Karting_496164
http://www.traveldownunder.com.au/new_sout...to_fastlane.asp
Do we want this to be a day or night thing???
I am thinking 29th March saturday after easter..
What do you guys think???
(Lol this emocon should say BAM!! :laugh: )
Have a brouse everyone :laugh:
Picton Karting Track
http://www.pkt.net.au/
ps: No Bam Needed Jeff
Yep links working :P
Its says on there calander saturday 29th is Seniors only (16yrs and older only)
Could you post up the Prices Joeyz as I cant seem to get them to come up on on there site...
I will ring Minto also just to get prices and session times..
i dont care what you say im Bam!ming the seats.
lol, i get it now :)
Dick Head :D
+LOL
ahahahahahahahaha... brads a dickhead :D
Its king dick head to you lot btw!!
:cheers: so we just doin one race or like a championship thing??
