hahaha how come r31nismoid gets to call people "retarted child" and stupid lol. personally i think if someone has a problem with someone else you should take it to PM. We dont need more name calling, especially from a moderator, as this just opens up a window for everyone else to call others what they please. After all this is supposed to be a friendly discussion forum aimed at assisting other fellow skyline owners. So, if you have a few little tricks and you dont want to share, you should probably not bring it up in the first place, as i can see why some people might see you as holding out :)
Sometimes friendly PM's just dont work ;)
Oh, and keep reading my post till you get the 'point', you should eventually.
Lets get back to the topic at hand now shall we?
Dont want this poor blokes thread closed down
hmm well if friendly pms dont work, doesnt really give anyone the right to start bad mouthing other sau members. i know cauz i got banned for that :). and please stop indirectly calling people idiots ;). its just not nice. You see i do get your point. however, you wording doesnt exactly imply what u claim to have meant :)
anywhoooooo enough said, as for the topic. there are a few people on this forum who were forced to pass an EPA test, and im sure they are willing to share their experiences with you. Mrgtr911 is an example.
good luck dude
hmmm yes...
Now this is the thing, i obviously know the way the car is gonna be on the road will not be EPA friendly.. BUT if it were to get an EPA id like to only have to change easy things for it to pass.
My main concern is the Turbo. What Turbo/Setup could i run (making a responsive 270-280rwkw) which wouldnt have to be changed if i were to cop an EPA? I know for a fact the labour to remove and re fit the turbo would be the dearest in process of getting the car through EPA.
Things like exhaust, aftermarket computer, BOV & injectors i dont mind not passing cos they aren't hard to change with standard parts if i get EPA'd. Especially since im running a plug in Microtech which can be plugged at any time!
Am I making sense? And can anyone give me some detailed advice...?
... OK back on topic, can someone read the above i wrote on page 1 and please respond if they understand what im saying??
I dont want a car thats gonna be permanently EPA friendly cos i think iv now realised its just almost impossible. Plus i dont want my car sounding like a Mitsubishi Magna...
Basically, I know my exhaust will never pass cos its F***** loud but i dont care cos in the event of an EPA i will just put a standard R33 exhaust on whicl will take me 15 minutes.
Things like the Computer which is just plug in will also take me 5 or less minutes to replace in event of an EPA.
I guess my main concern is what Turbo & Wastegate i could run which will make me a fairly responsive 260-280 rear wheel kws without having to replace in event of an EPA.
Replacing the Turbo with standard would obviously be the most costly thing if it wasnt EPA passable. Am i wrong?
So thats basically my only query now guys. What power turbo setup will pass? Changing computer, injectors, BOV, exhaust is not a concern for me with EPA cos they are small things to replace.
friendly pm's are for people who have friends.
anyways, swapping off the turbo would probably be the most expensive thing you do, yes. but getting a hiflow turbo and keeping it on would be better.
things like the computer wont really matter as i dont think they check for this. just your emissions.
so if you got a decent tune on low boost, and im talking 2-3psi (you wont reach any higher boost when they check your emissions as they rev it in neutral), it would be a different story if they actually drove the car, can someone confirm if they do?
EPA only conduct their tests with the vehicle staionary.
The problem you will have mate is that when you get pulled over by the police they can photograph your engine and note the mods, which you say you will remove when you get the subsequent date with the EPA. If this process repeats and the police/epa can prove (with those photos they take when you cop a defect/epa notice) that you are repeatedly failing to comply you can get a VERY large fine.
My 2c
When I got defected in my old R33, they didn't take any photos. Is this a new practice? My last defect would have been at least 2 years ago. :P
Also, to hijack a little but not much, any comments on whether an HKS 2835 Pro S would be much worse than a hi-flow in terms of emissions? I suppose it all depends on the tune. I guess if you run a hi-flow setup at 280kW and a 2835 setup at 280kW the emissions would be similar if not identical?
i passed the emissions test with a gt3540 & 740cc injectors, my car came off the dyno with 314rwkw 2 days before the test with nothing changed and passed.
Even with the 363 rwkw tune, i can still go down and pass emisions because the cruise tune is the same.
not many things have been said that have been much use to the kid.
i'll throw in my 10c, dean.
obviously the main things you are bound by are having to run stock management, stock fuel system, standard turbo, and legal db exhaust. in order, this is how i'd approach those issues.
1. ECU - its a nissan, get it remapped at dr.drift - the computer remains standard in appearance, so even if they open it up, it won't be possible to tell that the map has been tinkered.
2. stock fuel system is a bit of a bitch, because we all know that more fuel is half the equation to more power. now days they have gauges to apply to your injectors, so no point in even putting in stock 'looking' injectors. fuel reg is also a limitation - however, you could try the old 'tap down' method of increasing pressure - or run dummy lines to the fuel reg and hide an adjustable reg elsewhere - bit shitty and not 'legal', but is another way. other than that, upgrade the intank pump to the biggest item possible, and then run it off a relay so that it is receiving a constant 12V and will be pumping at the highest pressure possible.
3. Turbo, only way to do it without any degree of worry is to hi-flow it and steel wheel it as has been suggested. the turbo will remain stock in external appearance, but obviously perform better.
4. exhaust, not much you can do about this. however, you could possibly install a vaccum operated baffle, similar to the apexi EVC. have seen one in an HPI mag that opens using a wastegate mechanism when it senses boost. seeing as EPA only tests the car in a stationary position, the turbo will never come onto boost with no load on the engine. i know that the apexi EVC is illegal because it allows full control by the owner. but with a vaccum operated system this is not the case. and to further the argument, the golf R32 uses this exact method in their exhaust system, bypassing the rear muffler under full load.
hope that helps you out a bit mate.
Well the 2nd post pretty much covered it i reckon, yours indeed adds some good light too.
I have some points to yours though, to keep the ball rolling :D
1. Cant be done without a chip... or can it now? Been a while since i saw Sam in action with the R33 ECU.
EPA open the ECU covers if they suspect its non-factory, see a chip, its all over.
Im sitting not too far from the 270-280rwkw target on factory just about everything.
2. Stock fuel reg is not a limitation, nor is the fuel system for his aim.
3. There is more than one way to skin a cat.
4. I disagree, plenty can be done about it if you go about it in a good manner.
I have a 92dB exhaust, 3.5" with 80mm twin dumps, two custom mufflers (over 350rwkw of flow there). Just about have it to the legal limit @ 5200rpm.
I believe it can be done even easier than how mine as the R33 has more room to move underside than a low HR31 ;)
1. there is someone else in sydney who does remaps for r33's for around the $350 mark. i have spent alot of time and money on finding him so i will not disclose his information. LOL.
hit me up with a pm and ill give you his email.
2. Nismo FPR looks identical to the stock one, it even fits into the stock location. the only thing with that is it has an adjustable diaphragm which is visible.
3. You can get an aftermarket turbo engineered and the emissions test is done in neutral anyway, so it wont be hitting boost either way, in fact it will be leaner than stock since the turbo may spool at a later rpm.
4. i have no idea on this subject. i went from a 3" exhaust with a 5" tip, to a 3" exhaust with a 3.5" tip and it went louder. so im confused enough as it is.
Edited by SECURITY
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
