Hey all,
As many of you prolly know from my other current thread i've just installed a fmic on my r33.
My problem is to with my cars idling. I have done some searching through the forum about the whole need to retune thing and i would have to say the overwhelming majority say that there is no point in a retune if its simply just the fmic upgraded and nothing else (eg. no increase of boost)
So having said that why would my car run rough when it idles straight after start up?
Then if I go for a drive the car performs perfectly fine until u let the revs drop completely (like when u come to stop). The revs just continue to drop beyond the idle point and the car stalls!?
My car would randomly do this maybe once every couple weeks before the install so i just figured my aac valve failed occasionally. but now its non stop the car wont idle after being on higher revs.
So at the end of all this what do people think is wrong.
could it be that during the many days my cars been off the road the aac valve has become stuck closed.
could it be an air leak in the new piping for the fmic (but i would have thought this would cause problems all the way through the rev range like not hitting previous boost levels due to pressure loss)
or potentially does my power fc need some tlc at the tuners?
any help would be much appreciated as i want to be able to drive my car asap. (currently i'm getting around in a early 90's volvo and every time people see me in it a die a little inside ;))
Cheers
Camden
https://www.sau.com.au/forums/topic/201405-fmic-idle/
Test it by getting another AFM and seein if it still happens, i replaced mine recently and did the trick, if the change over aFM doesnt do ur car any just , there is a good AAC valve cleaning thread some where on here really handy...
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3579934
Yeah mate i did see that thread about the aac. Thinking i might give that a burl tonight as well as just giving my afm a clean out with some contact cleaner.
Only thing im a bit unsure about is doing the whole idle point reset as im not using the stock ecu anymore (power fc)
Cheers
Camden
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3580076
as in its just dirty or u recon it might need replacing?
is there a method of testing the afm? i don't really want to go out and buy one to find its not the problem.
know anyone that you can borrow from?
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3581067
Test each of these one at a time so you know what the culprit is.
1. tighten all clamps again
2. adjust the screw on the IAC valve while the car is idling, see if you can find a smooth idle point.
3. Clean afm
4. Check that no vacuum hoses have removed and not put back on during installation i.e. to charcoal canister.
5. Pressurize the intercooler piping, look for any leaks.
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3581364
Well i attacked the AFM and its connector with some contact cleaner yesterday and it seems to have made a difference. car doesn't stall anymore and in general drives fine but sometimes when coming down in revs it still drops a little low to then bounce back up to where it should idle at.
I've also noticed the car seems to be running quite rich as there is a lot of black splatter all over the arse of my car.
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3583948
on start up does the car still run rough or has this stopped completely? doesnt stall anymore? thats good if its problem fixed.
as for running rich, stick the car on a dyno and get it tuned again. imo a power fc doesnt learn like a standard computer, so a tune will be needed (correct me if im wrong). since it was tuned for a small side mount it only expects so much and now your cooling alot more air in a larger space.
my 2cents
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3584418
my 2cents
It starts up fine now.. and doesn't stall anymore, sorta. On letting the revs drop back towards idle it still goes to far, the car then kinda stuggles for second and then kick back to the correct idle position.
And yes the Power fc isnt going to protect its self etc like the stock computer. But something is causing the maps to be wrong and its running really friggin rich.. the whole back of my car is getting covered in black shite. Will def be back for a tune when i get free second (DAMN YOU WORK!)
Cheers
Camden
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3590719
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
