following on from the place that sells the alloy radiators
ive just picked up a nice price on oil coolers kits
ive gone through a few cars with oil coolers and these are the best ive seen at a good price
anyway what ya get
cooler kit with billet alloy annodised sandwich block and remote oil filter housing and 12 row oil cooler, -10 stainless braided hose with anodised alloy fittings, has two optional drilled and tapped holes in the billet alloy remote mount for oil temp and pressure gauges, and if not used has alloy bolts to block these off. Also supplied with alloy strap nuts and bolts for fitting to make own brackets, not pictured. Retail $395 group buy price $340 .
A bit more for supply of alloy bracket material and can't get any cheaper from supplier.
delivery they said 30 bux anywere in australia (thus why i recomend pick up cause it saves you cash!!!!!!!!)
what ya get
the box it comes in
opening it up
billet fittings
annodised alloy fittings
the whole lot
anyway they seem like a good kit, i cant confirm how well they work due to some fag flogging and smashing my car but its an oil cooler kit and hey they cool oil
once again i dont make any cash of these so be nice on the phone please
this is the price they offered, i am just a middle man and pass on money and you get the gear
anyway i encorage pick up to save ya money
https://www.sau.com.au/forums/topic/201645-oil-cooler-kit/
Hey fatz, ifI wanted to install oil pressure gauges and oil temp, does it have place for that? I was told they go on that orange thingy. Can you confirm?
And also, are they able to do a kit without the oil cooler itself but just the hoses?
https://www.sau.com.au/forums/topic/201645-oil-cooler-kit/#findComment-3583158
yea they come with the fitting for two guages on the block
Pete
https://www.sau.com.au/forums/topic/201645-oil-cooler-kit/#findComment-3583183
  • 4 weeks later...
