Item: 1 month old Sony Ericsson K800i (black) or BRAND NEW Nokia 6288 (white). I am only selling one of them since i need other for myself.
Condition: Nokia 6288 is unopened. K800i is in excellent condition with no scratch at all and still got plastic on screen and camera
Price: Nokia 6288 $400 or K800i for $275
Contact: PM me here or 0401380864
Nokia 6288
Form Factor
Depth: 21mm
Form Factor: Slide
Height: 100mm
Main Screen Resolution: 240 x 320 pixels
Main Screen Size: 34 x 45mm
Secondary Screen Resolution: n/a
Secondary Screen Size: n/a
Weight: 115g
Width: 46mm
Media and Camera
Camera: 2 megapixel camera
Resolution: 1600 x 1200 pixels
Camera Flash: Yes
Digital Zoom: 8 x digital zoom
Video Camera: Yes
Data and Memory
External Memory Type: Mini SDTM
Memory: 3MB
Battery Performance
Battery Standby Time: 162 hours
Battery Talk Time: 159 minutes
Video: Up to 83 minutes
Phone Features
Bluetooth: Yes
Email: Yes
FM Radio: Yes
Infrared: Yes
MP3 Player: Yes
MP3 Ringtones: Yes
Mobile TV: Yes
Polyphonic Ringtone: Yes
Speaker Phone: Yes
USB: Yes
Video Calling: Yes
Video Player: Yes
Voice Activated Dial: Yes
Voice Memo: Yes
WLAN: No
Whats in the box
Nokia 6288 mobile phone
Battery
A/C charger
Stereo personal headset kit
PC synchronisation software CD
USB cable
64MB Mini SD memory card
User guide
Sony Ericsson K800i
Form Factor
Depth: 22mm
Form Factor: Candy bar
Height: 105mm
Main Screen Resolution: 240x320 pixels
Main Screen Size: 41mm x 31mm
Weight: 115g
Width: 47mm
Media and Camera
Camera: 3.2 megapixel camera
Resolution: Up to 2048 x 1536 pixels
Camera Flash: Yes
Digital Zoom: Up to 16 x digital zoom
Image Editor: No
Video Camera: Yes
Data and Memory
External Memory Type: M2 Memory Stick MicroTM
Memory: 69MB
Battery Performance
Battery Standby Time: 144 hours
Battery Talk Time: 152 minutes
Phone Features
Bluetooth: Yes
Email: Yes
FM Radio: Yes
Infrared: Yes
MP3 Player: Yes
MP3 Ringtones: Yes
Mobile TV: Yes
Network Band: GSM,UMTS
Speaker Phone: Yes
USB: Yes
Video Calling: Yes
Video Player: Yes
Voice Memo: Yes
WLAN: No
Whats in the box
Sony Ericsson K800i mobile phone
Battery
A/C charger
USB cable
Need to dowload user guide and manual from sonyericsson site
Edited by R34NOS
https://www.sau.com.au/forums/topic/201658-sold-please-delete/
250 for k800?
Sorry K800i is not negotiable at all although i can negotiate on nokia 6288.. i really like the k800i camera and features :-) but if noone wants nokia i'll let go K800i for $275 only.
Thanks for the offer.
Cheers,
Manu
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
