Its called painting with light, it helps to add more light to the image, when using long exposures
thats cool, those bike shots are nice..i just bought a speedlite for my canon and youve given me some ideas..using an accessory flash is a pain in the arse to learn haha
i've read a little in the past about the whole painting with light thing too..pretty interesting.
awesome technique, how would you make sure that there's no flash spots in the end photo though... I noticed on one of them there's like a chrstmas light kinda effect, and on the others its not as noticeable. would you use like a diffuser or something to soften up the flash?
and yes niroj... I rolled up to the shoot point and went "ah shit, I'm on the wrong side". I should paint my car in two colours... like two face out of batman. one all f**ked up and the other immac.
yea that would be better.... and maybe a free sau BBQ?.....
lol do you want SAU to have your royal highness' penis cleaned too? :D
ok i wasnt there but from what i just read, this painting with light goes something like this: set camera on long exposure and then use an external flash to flash the car from different angles? am i right?
rofll
i call it i'm too poor to setup proper flash so i have to improvise!!
it's alright it's all i can afford to do too.... evade's seen my attempts :)
i like this one
http://www.pbase.com/joelstrick/image/91703937
looks funky with all the flashes
Sweet Pics, They came out really well.. what camera where you using??.. Thought id just Add , my bro has the exact same Bike, man its awesome, but im so sick of looking at it. He just put His Micron Exhaust Pipe on too. Now even Louder and more annoying, Bloody Croch Rockets.
Edited by Gazzilla
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
