hey guys
need peoples opinion. i'm looking at importing a R34 GTR later on and wanna know is it better to import it privately from japan myself or wether i should go thru a company?
i've heard both good n bad things that could happen to both sides of import it privately or thru company.
also is it hard to fish around for a bayside blue coloured gtr?
https://www.sau.com.au/forums/topic/201711-importin-a-r34-gtr/
i think that you should go through a company if you arent viewing it first, companies like imports101 have people in japan who inspect the veichles before you purchase them, importing privatly you might receive a car that has had the odometer wound back excessively and been in previous accident. plus if you go through and import place you should get warranty, do you know if there is much price difference from privatly importing or through a company?
You cant wind back digital displayed km unless you swap the dash I think and there arent may GTR 34's around so I think you'll find most later GTR's have genuine km...perhaps. Personally I dont think I could buy a car thats worth $50k plus and not even look at it
Got my car through www.j-spec.com.au and Ben Lippa sorts out everything for ya! Just sit back and relax and wait for your phone to ring ALOT!!
But for 1k, he does alot of work for you.... all paperwork, inspection reports etc... pretty much everything to get you through the whole process... negative side.. took 3months to arrive at docks from payment date!!
No regrets though!!!
For the record digital dashes can be altered. It was notorious in the Toyota Soarers. Apparently you can connect to them via a laptop and reset the display! These were hard to detect for auctioneers, only bad reinserting of dash and console left behind evidence of tampering. As for the R34, not sure?
Even iron chef imports he is a top bloke and goes over to japan everynow and then and hand picks the cars himself.
http://ironchefimports.com/site/
pretty cheap broker fee aswell :D
i'll have a look thanks wes=)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
