  • Replies 237
I will update the list tonight to see how many we have and number them, also to look how many supra people there are. Getting the car dynoed at ESP today for a before Dyno. Getting a retune done in between this run and March 8.
By the way, I never meant that we shoudlnt invite the Supra guys because they'll blow us away (power wise) I just meant that it will be an easy win for them if we are doing it as part of a 3 event challenge.
I dont like to lose :(
I don't think we will make this part of the 3 event challenge as I have mentioned this to ESP and they think that we should try and make this a NSW/ACT invitational to ensure that we have a lot of good quality cars.
There is even talk of prize money now to entice the NSW owners to join in.
The only way this will work if entrants are invloved in all 3 events.
More to come.
Cheers
Ross
So at this stage do the supra owners still wish to be a part of this, if it wont be part of the 3 events?
There are a couple that are keen pending their cars availability but I think a few interstaters won't be making the trip. I'll try and get you a list by the end of this week and I'll up date it when I get some more punters.
1. CeJay (R32 GTS4)
2. Towlie (R33 GTST)
3. 33 Sedan (R33 GTST)
4. Trident (R33 GTST)
5. ZCR (R32 GTST)
6. Nick (VL Turbo)
7. GZ R33 (R33 GTR)
8. Mad Max (F6 Typhoon)
9. LadyBytes (R32 GTST)
10.LadyBytes (R32 GTR)
11.Tarmac- (R33 GTST)
12.Turismo (Starlet)
13.TailsTails (R33 GTST)
14.SupaFly Skyline (XR6 T Ute or R32 skyline)
15.BNR32t (R32 GTR or mustang)
16.Bullet32 (R32 GTST)
17.GTS-T Sedan (R32 4dr)
Ok if theres about 20 people the day will end up taking around 5 hrs or so. Also if people are interested in a BBQ please tell me. ESP can do one for an extra charge, or perhaps we can organise something. BTW the numbers are in no particular order.
So if a few supras show up, should crack 20 people easy. People please tell me if you cant make it anymore or are unsure.
Its okay Cejay, I think you should go first for organising.
I guess it should be the order we committed to the final/confirmed date, unless someone advises they want to go later (sleep in).
I imagine there is a technical reason why we need to group car models? i.e. 4wd/2wd set-ups?
oh and Max and Nick pushed in line :) I'm hurt LOL j/k
i think the dyno plays up when u keep changing from 4wd to 2wd
i went to a ignition dvd dyno night two fridays ago and they were going from 4wd to 2wd and so forth
and so many cars were down on power
2 cars a r34 and a cefiro with a rb24 both with 250rwkw+ were only making 200rwkw :S
and they wernt the only ones
hmmm I wonder if thats what happened with my first GTR dyno run? It said something silly like 116rwkw which seems absurd when its pulling better times than a dedicated "race only" GTR getting around (with an excellent driver too) with trim/seats etc pulled out and running same tyres (now).
1. CeJay (R32 GTS4)
4. Trident (R33 GTST) After 10.00 o'clock is all
5. ZCR (R32 GTST)
6. Nick (VL Turbo)
7. GZ R33 (R33 GTR)
Just had my car on the ESP dyno for a first up tune,(getting it rechipped) did 173 awkw at around 1bar. Will see if the new tune is any better on the dyno day.
i think i might pull out of this one...
If its not going to be apart of the 3 event then with the supras not to interested in running my GTR on the dyno.
Might bring the mustang... Just put me down as a Maybe. If i bring the mustang i should battle the starlet for smallest kw per cubic inch.
i should have my totally stock chaser by then. 1jz gte with a zorst. A baby supra if you will.
if there are no objections i wouldnt mind tagging along to see what kinda of figure my car will put down stock
Cheers
I might be moving that weekend, but if i am not i should be able to join in.
1. CeJay (R32 GTS4)
5. ZCR (R32 GTST)
6. Nick (VL Turbo)
7. GZ R33 (R33 GTR)
18.Donnan (R32 GTR) (possibly maybe?)
I will probably come 2 but not definate, i gotta sort a few things out with my ride.
R31
RB25DET
May have another car or 2 coming aswell if its not strictly skylines or forum members.
A Turbo V6 VR
A 13BT RX2
Do you need a defenite answer?
Peace.
Edited by whiteRB25det
1. CeJay (R32 GTS4)
5. ZCR (R32 GTST)
6. Nick (VL Turbo)
7. GZ R33 (R33 GTR)
19.Ex!$t3nZ (Toyota Chaser, if no body objects)
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
