has it just started doing it?
have you done any mods recently to cause it? i.e. spark plugs, exhaust, timing, etc?
it's not exactly normal, but also not surprising.
the fuel mixture does normally run rich in the high rpm range.
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3588962
mine does it aswell, nearly all the time in 3rd.
its just because the fuel runs rich then when you put your clutch in all the unburnt fuel thats left sitting around pops.
its not a bad thing.. i personally like it as mine sometimes makes a tiney flame :(
when i get my safc2 and get the air/fuel mixture tuned it will stop this..
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3590386
check the forced induction section man there was a technical write up about it..
basically your car is running rich.. when the fuel comes into contact with oxygen it creates a popping noise.
thats about all i can remember. but it is in the FORCED INDUCTION section.
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3592569
thats called overrun
thats different to backfiring cause the engine is at high-ish revs, but there is no real load on the engine, and so it revs without using the accelerator
there is an excess of fuel in the burnt mixture because of the closed throttle, and when it hit the cat converter it mixes with a bit of oxygen and self ignites
thus the pop/gurgle/burping noise
backfiring is like a full on ignition of fuel/air mixture partially in the engine and in the exhaust - thats why its loud and bad for your engine
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3592934
I love my NA,
Going threw shopping centres as your slowing down, makes all the burping and dull popping noises.
Every one looks :(
grrrr lol while I sit at home on Fridays when I don't feel like spending cash going out bored out of my mind hahaha
edit: Yea the only part of the exhaust that was still stock was the cat. So in the future if you ever wanted to upgrade something I'd look at getting a high-flow cat maybe, but yea it sounded and went nice anyway =P
Also have you done anything new to it?
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3597699
Just a few little things here and there.
Changed the gear knob pretty much straight away, has a gt nismo titanium on there now, lining up a new clutch soon, and also suspension. but besides that, shes still the same from the day i drove away.
Hows your legs going for transport?
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3599594
Ahhh they go ok, thinking of lowering them a little and putting some 18's on there :laughing-smiley-014:
https://www.sau.com.au/forums/topic/202039-car-back-firing/#findComment-3600946
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
