Hey guys, im going to be doing this tommorow for my rb26,and was wondering what sort of guides people use when doing theirs, ive searched the forums and there seems to be alot of guides written differently,.....
Im doing my belt, tensioner, idler and waterpump all at the same time, and words of advice greatly appreciated, as its my first time, so far, i can see timing marks for my inlet exhast on the cam cover, and also cas marks were there already aswell...
What confuses me is all the marks on the bottom pulley going down the side of it (looking front on at the engine)
Thanks.
https://www.sau.com.au/forums/topic/202047-timing-belt-change-in-rb26dett/
the mark on the crank cam (the dot) lines up with a mark in the alloy case that surrounds the cam, with this mark lined up (has to be dead on) slide the balancer on and the mark on the balancer should line up with the TDC mark on the timing belt cover.
if it doesnt then your all on drugs
yeah, that makes more sense.
though at the end of the day you can ignore the marks on the harmonic balancer as they are only there to help set the ignition timing and nothing else. Only the crank gear and the notch, and the cam gears and their marks on the back cover matter.
And the genuine nissan belt has marks as well incidentally. double fail safe.
Thanks, so any cas sensors from early models with the mitsi logo should work?iive been looking at a couple of pictures and they all seem to be exactly the same as mine....if it plugs in and keys in aswell is it safe to say its for my car, or should the cas sensor part no. match up....could i screw anything up if its the wrong sensor?
heres the part no for my cas: 23731 02U11
Further information regarding my issue, when the car starts...and everything is lined up, it feels like its about to turn over, and then the noise of air going through like vaccum to the intake, and it ends at my arc panel....its a wierd noise to explain....
whats this mean?, or could this relate to my cas being faulty in any way???
Edited by r33turb
Hey, yeah its like it just needs that slight KICK to get going, its hard to explain, but then when the cas timing is right on, this wierd noise comes through the intake, like huge vacuum pressure going out the intake and through my afms - panel filter(where it seems to stop making the noise).
Ive cranked the engine by hand, and all seems ok.
I also lined up my timing marks at tdc, removed cyl 1 spark, and piston was right on TDC, so timing looks to be correct.
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
