  • Replies 48
has some one put it on youtube yet
I hope some does soon
is that 200sx owner the guy from Ignition DVD?
I never seen that Ian Luff bloke before but man he is a dead set tosser.He moves around and laughs too much. STFU and drive the car d!k
Luff is alright, I havent meet him yet, but he can steer a car!!!
I thought it was Loz owner of NS.com :P
pfft... not impressed... only 2 cars actually managed to get down the 1/2 mile remotely cleanly... well done to the RX7 guy getting his car fixed as he was one of them... don't know how you see outta the windscreen with all those stickers tho;)
Ferrari looks great but that's about it, left the line with clutch smoke billowing out the back of the car = $$$
everything except the 2 imports and torrie seem to have waaay too much power and zero grip (and the owners couldn't drive to save their lives)
Luff never has anything interesting or intelligent to say other than "it has heaps of power" and if he sat in the passenger seat yelling at me like he does I would have to open the door and kick him out
these are supposed to be street cars but most of them would be really average on the street and evidently rubbish on the track too... they all look absolutely mint but the point is the're super quick and good at everything, right?... just don't see the point in the show...
I dunno just felt like it could have been handled more professionally, makes us all look like meat heads IMHO... that's not the guys who were on the shows fault... real low budget, rushed car show once again... lets hope somebody throws some money at the Aussie Top Gear
geez did anyone see the show tonight?
dont worry, it was bloody shit house! all they did was show wat they done the last two weeks and bloody talk, then when it came around to the actual event this week, they just showed snippets of the cars goin round the little course they made. and then that was the end of the show!
but at least Dom won this weeks event!!!!
Yeah the show is going from bad to worse. The guy with the Ferrari couldn't be a bigger tosser if he tried and apart from Dom (and Andrew because he is yet to have a go) the rest aren't taking anything seriously and wouldn't have a clue where the brake pedal is.
I'm not sure why Andrew was out of this weeks event, I don't know how closely they filmed each episode but I wouldn't think it would take more than an afternoon to source and fit 2 axles on a 200SX in melbourne.
I can see why this show is on Foxtel only, it wouldn't last a week on FTA.
  • 3 weeks later...
According to a federal cop mate, at least half these guys are MAJOR importers/dealers of illicit substances (sorry, under investigation for said crimes).... so that's how they can afford such sweet cars.
Mate ths is a public forum.
Unless this information has also been reported in the papers or released officially, you better hope the boys on TV don't read this post because your ass and your copper mate's ass is theirs.........without evidence, even if they're only under investigation, this could be seen as slander.
Nightcrawler, for timheather's sake, it might be a good idea to remove this post.
thread is ok its content in the thread hence why i deleted my so called funny comment because i realised i may no be so funny @ all
Yeah you're right Steve, I meant "post" not 'thread"...........I've now changed that.
What slander mate? I never said who.... :)
You didn't have to mate. There's only a handfull of guys on there and the fact that the public can now put them all in the same basket is like opening a can of worms. If your info was backed with evidence or it had already ben reported in papers you would have been better off naming them just to exonerate the others.
Sorry to be so hot on this subject, reason being is that I have also been accused of links to outlaw bikers by someone who barely even knows me just because of the toys I have.
He's about to learn the meaning of the word litigation if he dares to start slandering me in forums.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
