Hey guys. I'm considering to lowering my Stagea. Currently is on standard height with my 18x8's on it. I'm considering lowering it by 1 - 1.5 inches. I want it to look nice and low but able to carry back passengers, cargo and get over speed humps but not make it too illegal.
A friend of mine said to get some Kingsprings..
What ideas can you give me and how much would it cost
https://www.sau.com.au/forums/topic/202380-lowering-the-stagea/
bilstein shocks from Sydneykid on this forum http://www.skylinesaustralia.com/forums/St...mp;hl=group+buy
can also get his whiteline springs.
also a rear camber kitwill be needed; front camber kit, front castor kit are also money well spent.
I would do the Shocks/springs/bushes then whatever/whenever, or shocks/bushes then whatever/whenever.
Doing just springs will damage the shocks, using the Height adjustable bilsteins shocks will be awesome!
-Ryan
SK kit all the way. I just got mine readjusted to the lowest of the SK settings, and it is awesome! Still a reasonable height, too. For reference, I run 18s as well, and the ride is firm, but acceptable.
Sorry to hijack this thread but has anyone used the Tein coilovers on a stag yet?
Yes, got TEIN super wagon's on mine, good firmness, not too much though, height adjustable, just be sure to grease the pillowballs before you install, squeak, squeak
Fantastic - how low does it go? I want it to be LOW :P
Of course i'm going to replace the shocks on it. Was considering getting Bilstein shocks as well. I've got a few really good suspension places where I live and can give me some good advice (good friend of mine works for at one of those places)
A few of my mates have advised me to install Tien goodies. but I really can't justify the pricetag and for me personally I don't see any great use for me
http://www.skylinesaustralia.com/forums/Te...-h-t199188.html
Check out my thread, StageaNut and Jason. Am VERY busy atm but have two offers on the table in regard to swaps. Depends where you are. My avatar pic shows my Teins at very close to the top of their adjustment range. Will drop so that tyres are inside the guards, comfortably! They are similar to Super Wagons but are slightly firmer in the front and slightly less firm in the rear (to match weight distribution). PM me if you like.
Ok just went around and visited my mate after work to talk shop...he's convinced my to go with Tein coilovers - either Hybrid Wagon or Super Wagon... He's going to get back to me with prices...One thing i'm not going to install is the EDFC Controller from what i read it requires the rear tops to be cut out and not able to use the rear shade (knowing my luck it would have to be cut out regardless)
Can you tell me what the difference is between the Hybrid Wagon and Super Wagon Coilovers??
SK do you still have the link for suspension settings. i can't find it on the Group Buy page.
I have fixed the link in thre Group Buy thread
http://www.skylinesaustralia.com/forums/St...lin-t85592.html
The recommended settings are also in the Stagea Suspension thread
http://www.skylinesaustralia.com/forums/St...ion-t53079.html
Cheers
Gary
Most people find the Japanese spec Teins to be too harsh, so be careful in your choices. Adjusting the rebound damping has almost zerro effect on the ride comfort, so shock adjustablility won't help you.
Cheers
Gary
go for a ride in a car with teins, then go and buy bilsteins :D
Well that's the reason I don't Teins...I've got two mates with Tein Super Streets installed (one in a skyline and the other in an 180SX) and my god the ride was frim if not hard.
I'm going to some very good suspension places in my area and shop around for some prices.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
