i would definately been keen to see the car, ive been looking for a gtr for a while now and there are a lot of bad ones out there.
the only problem is, i would have to travel up from melbourne to see the car.
i will let you know in the next few weeks (if the car is still for sale then of course).
good luck with it in the mean time.
https://www.sau.com.au/forums/topic/202435-sold/page/2/#findComment-3624250
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
