Went to look at an R34 on the weekend, and I was told that the washer bottle had to be removed to install the intercooler piping.
Is this a common problem? Or is it only with the Just Jap kits?
What have you guys done to fix it? I'm pretty sure it's not roadworthy to not have windscreen washer jets, and also it would be pretty inconvenient...
Or does everybody just use the turnflow intercooler kits that go through the stock piping locations..?
Thanks
https://www.sau.com.au/forums/topic/202490-r34-owners-help/
Yeah, I've got a few on the shortlist :D
i havent installed on into a r34 yet, but a mate has a r34 gtt with a front mount and he retained his washer bottle, not sure if it was a just jap cooler though. Even if you couldnt keep it in its original postion, i cant see it being too hard to relocate it, or worse case situation just make up a custom washer bottom from some s/s and mount it up, it would look pretty too haha
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3597631
Thanks for that PJ, I'll have to check it out when I go look at the car again.
Only problem I can see is, the car that I'm 90% sold on has the standard series 1 front bar, not the Nismo one.
If not, I could always do as Stephen suggested and get a custom one made up
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3597643
could be similar, I don't know as I have an aero front bar...
I had to rewire the pumps and extend the hoses once I twisted mine as the standard wires and hoses weren't long enough to reach the new position.
Hope it works out for ya,
PJ
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3600022
Thanks
or you could keep the stock intercooler (good for up to 200rwkw apparently) - and get a water spray kit (extra washer bottle) to take it further...
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3600383
I just left my washer bottle off. It's not like you need it when you wash your car every week. I also keep some Windex wet towels in the glovebox just in case. There is NO room in the engine bay to fit a similar capacity replacement reservoir - you would struggle to fit anything of half decent volume in there - especially since I have an oil breather kit, and a radiator breather kit.
Or if you are dead keen on it, you could mount any sort of container in the boot and patch up some wiring, piping and a motor to it (the piping is already done for me in the form of my rear window washer). I am actually going to do this with a 20 litre plastic jerry can and put in a FMIC & radiator spray system for those nasty 43 degree Adelaide days (I sit around idling in my car for up to 15 minutes at a time while working.)
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3602021
It all depends on which FMIC kit you get. The more common alternative which is proven to gain more power and also cheaper is the r33 fmic kit which can fit onto a r34 but mods needed such as quiet a bit of angle grinding and also removing the washer bottle to accomodate the piping. another alternative is a bolt on kit for the r34 which has longer piping but retains everything since its a replacement kit
hope that helps
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3605724
the japanese branded FMIC will not require any mods such as removing the washer bottle. Only justjaps will require mods like that such as trimming fans etc. if its the 'Cooling Pro' ones ur talking about
Edited by R33Turbo
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3606826
Bollocks. Any R34 intercooler kit that has an entry at either end, and does not have a hideously bad flowing 180 degree bend to follow oem pipe path, will need the washer bottle removed. The R34 washer bottle takes up the whole inner corner between the drivers inner wheel guard, and the power steering fluid cooler. Hybrid is one of the largest makers of intercooler kits, and they require removal of the washer bottle. The Trust and Greddy kits I have seen all have a similar piping path, which requires a hole to be sawn under the battery position, and that whole wall of the engine bay has washer bottle along it - so there is no way to get around it.
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3607022
Agreed with that. Mate has a HKS intercooler, he has to remove the bottle as well because of the piping that goes back into the engine from the battery side of the car. So it doesn't matter what brand, basically it's the design i reckon.
https://www.sau.com.au/forums/topic/202490-r34-owners-help/#findComment-3607061
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
