rb25/30 NEO with all the fruit to match. Using t04z 1.00 a/r turbo and npc twin plate. Only time it will be pushing high boost is on the dyno. 99% of other time is sensible street driving on low psi. I want to push the turbo to the limits and see what the engine can achive. Hoping for 620rwhp. Is the box going to totally crap itself at this level? Many factors to account, but for argument sake, perfect condition box. What kind of power level are other people getting away with?
https://www.sau.com.au/forums/topic/202550-torque-of-2530-on-a-rb25det-box/
If your only loading it up on the dyno, it will be fine, as dyno pulls are done in 4th which is 1:1 where there is minimal load on the box. Just try to minimise the shock loading and make sure you cleanly engage the gears on the street(especially 3rd)
cool thanks for for input. Anyone have or known of other simliar setups pushing what kind of power levels? Was also told that nismo engine mounts wont do and that the engine will have to be chained down!
The gearbox and the engine mounts will be fine - especially if it's a dyno queen. The VL boys are running mid-nines with R33 5-speeds now and they're copping more load than you could ever put through a box on the dyno.
yeah a guy i know is professionally drifting his rb25/30 on a standard rb25 box
making about 400rwkw and 800nm of torque i believe, with the shock loadings that drifting puts on all the components
and it has been standing up for ages just fine!!
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
