Yo finally got the bolt off tonight, i tried a huge assed pair of grips as a last result and then grabbed a hack saw and cut it off, top half of the cover is off and the belt and everything looks fine, not even a scuff (i expected some tears from the little cover bouncing around)
Will hopefully pull the bottom half off tonight if all goes well and i dont run into any more nuts that need undo-ing i'm guessing the tensioner being talked about is one of the two, half way down inside the bottom of the case that sit on the sides and push the belt inwards?
thx ppl!
  • Replies 41
Posted Images
good to hear you got it off * now you know why mechanics charge so much, not because its hard but because when shit like this happens we get headache's :( * lol.
your also corrrect about the tensioner and its considerd good practice to replace all seals,bearings,studs,water pump etc.. i'd suggest this if you dont wana be pulling this shit appart again... other then that tehres the old rule, if it aint broke dont fix it. up to you
lol yeh true, crap like this only seems to happen when i work on skylines though, zz. Waterpump is pretty new and timing belt but i'll probably replace those other things u suggested once i find a thread that details which they are and part numbers, cant seem to dig up my workshop manual atm
Yeh previous owner changed it just before i bought the car so i don't have to worry about that.
I'm hoping i'll be able to get a replacement stud, this one came loose pretty much as soon as the nut was cut off luckily, otherwise i can probably ghetto spec something out of a nut and bolt to replace it
Now i've just gotta find a socket big enough to fit the crank pulley nut, yank it off and then it's pretty much just a matter of waiting for parts/putting it all back together i guess.. (btw wat size is the socket on the end of the crank pulley? I've read 23 Mm for a rb25 but a 23 won't fit and this looks more like 28, which i dont have)
Hmm i'm just looking at the engine manual and wondering about a new oil pump.. I will be alot less worried about the car with a new one and it looks like it bolts straight onto the front of the block.. If this is the case and i already have the pulleys etc off then it wouldnt be that difficult to replace.. is it worth taking it to a mech to get it replaced? Or is the sump etc going to need to come off to take it apart
Edited by GTAAAH
dont quote me on this as ive never pulled a gtr sump off, however from every other engine ive pulled down the pick up is attached to the oil pump, meaning sump off, which could also mean engine out for gtr, like i said though dont quote me, duncan would know 100percent.
wish I did know, but I've never tried. I would guess you can do it without sump off (the pickup is further back in these) but I'm not 100% sure.
I've always had motor out when I've done the oil pumps.
K i've asked the Q with the pump and u do need to pull everything apart to replace it so i'm not going to bother (it's a 93 ne way)
However, i need to know where i can get a crank pulley remover to fit. I have a standard one that works on most cars (it's pretty much just 3 claws that u attached to the outside) but it's sorta small and i cant get enough leverage + i'm worried about chipping the edges of the pulley. Bursons sells a remover for $250 which is too much.. i was speaking to someone who told me they got one for $20 to fit (it fits the notches in the balancer, isntead of gripping the edges) but i can't remember who/where.
Can anyone give me a part number or a store that sell them cheaply?
Thx.. i wanna get this thing back on the road zz
Edited by GTAAAH
don't use a 3 arm balancer puller you can easily break the lip it pulls on.
You need this style
If it doesn't come with bolts make sure you buy high tensile ones and screw them all the way in. If you break off one in the balancer you are screwed.
if u have a supercheap near by the have a harmonic balancer remover that works as thats wat i used it is around the 20 mark but u will have 2 get sum bolts 2 fit the holes in the balancer as the 1s in the kit wont fit ill mesure the bolts 2morrow and post them up 4 u. the radiator has 2 b out 2 for it 2 fit properely and ends up with bout 10mm till the ac cendensor. hope this helps
yeh cheers dude, i wasn't keen using the 3 armed one, i have the radiator out already so that's all good. i'll go try find one of these tonight after work.. and if i can't i'll just throw it on a trailer, drive it somewhere and say "fix" heh, i'm so over it
got one of the tools duncan had pictured and am slightly confused.. Where do u screw it into? I thought the pulley face had holes in it to put the bolts through but it doesnt... i can see a 2 small holes (you'd break bolts if u tried to lever off them, they like 8mm) about 3 cm out from the centre bolt but nothing else on the faces (except for about 6 slightly drilled holes on the outer rim which are useless.. any suggestions
K finally got around to pulling this off (had problems with the pulley remover.. needed to cut some stuff etc to make it fit), one of the tensioners was bearingless and they had collected just below the crank gearing (they fit in the gap luckily so didn't cause jamming), anyways, if possible does anyone know the serials for the idler pulley and the belt tensioner? I was going to go to our local nissan dealer and just ask for them but i'm sure they'll charge like crazy
cheers
Yeh i know ay, lucky as
I've been searching for a while and managed to find the part number of 1 of the bearings but can't find the other so i'll dwnld and install FAST tonight and see if that helps me (I'm assuming it has all the part numbers for these things on it)
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
