No sympathy for him from my end whatsoever.
+1....
How is he a hero? He made movies ffs. not like he rescued a baby from a burning building or anything.
And the stupid f##k kills himself with sleeping pills.
No sympathy for stupidity
+1 but maybe not so emotional....
farken Batman better still be coming out...i think he finished it before death got him....anyone have any incite into this?
as far as i know the film is in post production stages.
i think the real tragedy is he is survived by a little girl, hope it doesn't f**k her up
i have seen a preview for it.....so i hope so.
Lol, "Hes not a hero" so much hate on these boards sometimes =P
Yeah they said a few days ago that Batman will still come out, hes even in another one thats still yet to come out too, which might be a bit weird.
<shrug>
new batman movie musta been real shit for him to have to do that.
not really a big heath fan anyways... his acting was a lil lacklustre in the big hollywood movies he did.
ah well RIP.
Why all the hate?
i suppose it is from some mofo's who come on here all new and stirr us up...or its just that we are around skylines alot......
ah well RIP.
lmao.....it actaully looks groovy.
+1 for his acting...but have a look at a preview i think it will change your mind...it actually looks like he is going to do an ok job...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
