I Have a set of 4 x 18' BBS in wheels in Shadow Chrome for sale
They come with 265/35/18 Yokohama Advan Neora Tyres with around 80% to 90% tread left
They are currently fitted to my R34 GTR
The Wheels retail for $850.00 each US and the tyres for around $500.00 US each
I'm asking $1600.00 ono for the lot
The wheels can be inspected at Wetherill Park NSW
Ph 9725-5577 Work hours
Edited by JonoT
https://www.sau.com.au/forums/topic/202792-bbs-18-wheels-for-sale/
Could you please give width and offset and the condition, any gutter rash etc
Yeah will do. I'll post those details tomorrow.
As for condition the wheels are in very good condition. I think only 1 wheel has slight Gutter rash but nothing to serious I'll see if i can get some photos up as well
Thanks,
Hi Jonathan
I called the Wetherill Park No. this afternoon, but maybe you didn't get the message...
My name is Terry and I'll be happy to come over this weekend and inspect the wheels. Since I also have a R34 GT-R I'd like to see the wheels on your car still, if I could.
My E-Mail is [email protected]
My Ph No is 0416-214699
Regards,
Terry
I don't need these for myself. But one of the guys in our GT-R club would like to view these.
Are they sold or still available?
Regards,
Thomas
BBS RG-Rs are invariably 18x9.5+20 you can't see it very well, but the sizes and offset are stamped into the front of the wheel. From the second picture I can make out something resembling 9½Jx18 but there should be ET20 on it as well.
This is a stupidly cheap price. Whoever gets these is getting a great deal.
Edited by Laurence
Theyre sold. I have them :D
Arrrgh, I hate you!!! :P
Could you take a quick look and see if they say ET20 and 9½Jx18 on the face near the centre cap?
These are one of my two favorite wheels... I have been chasing a set of 17x9J+14 so you can make a nice 17/18 staggered set of wheels for something like an S15.
Enjoy your wheels kkkk :(
Well that certainly is an upgrade, in both spec and baller status.
Anyway, what are you doing online, you should be outside drooling over your wheels, then wiping them clean, repeat...
that is what I would be doing :)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
