*Extreeme 9 puck ceramic clutch plate , sprung centre. KNI24001 r32 gtr/gtst and R33 gts/gtst
*Matching upgraded pressure plate off 1990 R32 GTR
* standard GTR flywheel to suit.
Done less than 10,000kms heaps of meat on it.
Great clutch setup.
$400ono
Edited by rev210
  • 1 month later...
Nothing wrong with Xtreme clutches.I have given mine an absolute hiding for the past year and still feels like new.
7000rpm second gear clutchs kicks FTW!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
