The need for heat treatement of CM seems to have gone now that most people have the TIG requirements (temperatures) under control.
There are plenty of already engineered CM cages now, so the engineering costs are not as relevant any more. They simply sign off on a pre-existing design, no analysis required.
Chrome molly cages are a joke. Stupidly stiff brittle cages that don't give any flex whatsoever in the event of a crash, and due to the self-hardening properties of CM, will crack by themselves over time... CD Steel will stay joined together under a high load for a lot longer than CM. Drag cars aren't allowed to paint their tubes as the welds need to inspected every 5 mins of race time for cracks...
If you value your life, don't get a CM cage. After about 2 years they start to become weak, and very easily broken in the event of an accident. The death at Bathurst a year or two ago up the top, failed CM cage, the heart piercing bar that let go in the ex-rospen WRX at Jimna couple of years ago, failed CM cage... Chris Atkinson at Rally Japan last year where the cage just fell apart... FAILED CM CAGE!
There's a reason why the FIA has just banned Chrome Molly Cages in rally cars, its downright dangerous... To properly weld Chrome Molly is a very long and drawn out process, and very few can do it properly... and even when done properly it still only has a maximum useable life of 3-5 years maximum...
This isn't any help for you guys in Sydney but this company does a very cage and start with a 6 point CAMS approved for $1850 I think.
I'll get my car back with the cage fitted next week and will put some pictures up.
http://motorsportsolutionsaustralia.com/
Thanks for the plug! Appreciate it! ;)
  • Replies 41
...To properly weld Chrome Molly is a very long and drawn out process, and very few can do it properly...
Agree, i cant speak for those that care currently manufacturing cages using CM, but the thought of ppl not utilising post weld heat treatment/stree relief is a concern. Sur eyou can control heat inptu pretty well with TIG, but doesnt change thge fact that you are changing the grain structure of the material (and surrounding) when welding it...
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
