Guest trikdoutvl
f*k yeh im so there with my skyline powered commodore OOO YEH, its gonna be like being beaten to death with ur own shoe LOL.................. jokes jokes,, were all gonna get along no matter wat we drive cause at the end of the day no matter wat u drive we all just wanna do skids woooooooooooooot wooooooooooooooot :D:laugh:
  • Replies 49
Posted Images
*cough* im sick cant work this swing lol
haha tell ur boss ur have a new desisese called driftillitis haha.
any ways i will love to go but i do not think my R34 gt will cut the bread!
i will come down and look but
DINOBONED - its is not a car comp its a BIG BIG car cruise with the extra's more cars are better trust me you will regret it ") m
Not necessarily. If you car does not have enought power to do a big skid then it is probably best that you dont enter. THis type of thing is not for everyone but yes it would be good to see a few Nissans at the track.
Not really just a cruise - kind of a cruise/driving event/ car show mix.
do you think the SAUWA support n recovery vehicle would be suitable for the power cruise?
by then the audio system should be complete and if you want to see the list of mods so far then visit
http://www.fordforums.com.au/showthread.ph...age=1&pp=25
Nice car dude.
Can it do a skid?
Nice car dude.
Can it do a skid?
hahahaha... i have broken traction twice... both times in the wet!!!
its a little hard to brake traction even with around 250Kw... the 4 wheel drive system and traction controll is just too damn good. Once the warranty runs out I will get the ecu flash tuned and get it over 300Kw... then it will squeel!!!
unfortunately the warranty only runs out near the end of 09' so there wont be any more power up's until then.
i cant wait for the powercruise #15 gna b so sweet, no havin 2 stresss wat speed ur doin tackin a corner nd gettin a cop on ya or racin a buddy, jst do it nd kik ass woooo. go skylines!!!
Edited by Ryan's 33
  • 1 month later...
  • 1 month later...
  • 2 months later...
so what's going on?
how do i get an entry form etc.
hey guys how are you all going . Um to enter with the form is to late now, but you can still rock up at the gates and pay for it and enter the car that way. but read all the details at " www.powercruise.net " as you have to get your car taken over a check up there such as there own pits, which check if you car has legal limit on tyres, if all the brake lights, indicators and so on work. also you have to bring proof and also rego forms for car.
have a good one,niran
AHHHH POWERCRUISE 08 WAS AWSUM!!!
Didnt see many skylines there which was quite surprising, but the phew i did see i tryed to say hey. The guy with the custom 2 tone 32 who was next to us (Tuned WA) was a champ and an excellent drifter, and the guy with the GMG 4dr 34 with the drfit wing - i'm sooo jealous i want gate + screamer haha sounded mint!!
Of course i have to say [ANGR33GTS] has some serious drift talent, i hope someone saw u coz u could go far with that.
It was an awsum weekend and will deffo enter next year.
Edited by Angr33_Sparcorella
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
